I've done some searching with very little satisfactory results. My issue is, without verification, that my tach is of by 400 rpms or so. At warm idle it reads 1150. To my ears and body, it sounds and feels like 750 or optimal range at least. What ways can I verify this. I can deal with the tach being off as long as I know it's actually true.
tach off by 400rpm?
What year and model Accord? Auto or 5 speed? Did it happen suddenly, or gradually shift over time? Do you think it is shifted (400 high all the time), or is it even more off at higher engine speeds?90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
What happens if you disconnect the IACV? Find a deserted road. Put the gear selector in 1; let the engine idle at the 1150 rpm and see what speed the car attains (level ground). Same thing for second - for both gears, accelerate above the 1150 rpm, then let it settle back to 1150; note the speed it maintains. Running stock size (195-60/15) tires? With this info, we can estimate the engine speed.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
