I need some advice on this one.
I need to get my transmission mount replaced (which is a must). I recently changed my ATF which showed signs of metal debris on the bolt plug. I was advised by my mechanic it would require changing the transmission, but I could drive it for now until I decide to change it. I would like to get a 2nd opinion on if I should change the AFT again and see if the debris is still there (maybe it just needs flushing).
I was quoted: $400 labour + plus seals & fluid for swap. Lucky I have access to a spare A/T.
Now my dilemma is do I go ahead and change everything: Entire Transmission, mount, seals etc. in order to save on labour cost OR can I just change the tranny mount now and do a tranny swap later (early next year).
Also are there any factors to consider for the F20A engine and a regular (F22) transmission for replacement.
