I finished my rebuild a few months ago and last week my car started the dreaded 2000 to 1000 idle drop. I searched on here and a few other spots and commenced the process of elimination. I cleaned the already clean IACV, Adjusted the FITV and cleaned it, cleaned the EGR Valve, Even went as far to block off the start boost valve since I read somewhere that its recommended when running a hopped up cam. Nothing stopped it. Checked the whole thing for vacuum leaks a dozen times, bled the coolant system a few times. I finally gave up and just started reaching for anything that might help and first thing I tried that I never seen listed was back off the little throttle stop screw Its a pain to do on a hot motor, but shes right where she should be on idle now. I apologize if anyone else has posted this potential fix, but just in case no one has I wanted to get it out there.
The up and down Idle issue - Possible update.
Originally posted by ravenexi View PostI finished my rebuild a few months ago and last week my car started the dreaded 2000 to 1000 idle drop. I searched on here and a few other spots and commenced the process of elimination. I cleaned the already clean IACV, Adjusted the FITV and cleaned it, cleaned the EGR Valve, Even went as far to block off the start boost valve since I read somewhere that its recommended when running a hopped up cam. Nothing stopped it. Checked the whole thing for vacuum leaks a dozen times, bled the coolant system a few times. I finally gave up and just started reaching for anything that might help and first thing I tried that I never seen listed was back off the little throttle stop screw Its a pain to do on a hot motor, but shes right where she should be on idle now. I apologize if anyone else has posted this potential fix, but just in case no one has I wanted to get it out there.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
My issue was my throttle cable. Its supposed to have 10mm of play. Mine didn't.MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
Originally posted by ravenexi View PostYeah I drove it hard and fast , then drove miss daisy and ways and it stayed away. I'm pretty sure I got it. If it comes back soon Ill post it.Originally posted by Mishakol129Do not disrespect my intelligence. I am the smartest person I know : )
If you are talking about the throttle stop screw located at the throttle body bell crank..that's a no no.
According to Honda, you are not supposed to touch that screw. Apparently, the throttle position sensor is calibrated very carefully with this screw. Also, I don't see how this would solve the 1,000 rpm idle fluctuation.
I would be more inclined to think the brass "idle speed screw" at the top of the throttle body would be a better candidate. This is not actually a "idle speed screw", it's a "idle mixture screw". Turn it out for lean mixture (usually faster) turn it in for rich mixture (slower and lumpy). If Honda called it what it is, they would need to put a cap on it.
No no or not it worked, As with any potentiometer (which is what your TPS is) the resistance will change over time. Considering that I am running an A6 manifold with a P12 ecu they could have never been calibrated together any ways. I figure the issue was years of throttle use had slightly wore the throttle plate just enough to allow more vacuum past it which was confusing the map sensor and IACV. Just like a vacuum leak.
I had the same problem and it was a simple fix. I found the culprit to be the engine idle control valve! When you remove the cap on the top, you will see a probe with a plastic ring around it, and the ring has two flat slots, tighten the ring all the way till it's tight, and just like that problem solved! The problem is that these cars are very coolant dependent and if air gets in the line it causes your idle problem, having the ring loose allows air into the line causing your problem. Hope this helps someone in the future!Current
1992 Accord EX 5-speed Sedan
Rosewood Brown
1992 Accord EX 5-Speed Sedan
Arcadia Green
Previous
Bordeaux
1993 Accord LX 5-Speed Sedan
Bordeaux
Originally posted by ravenexi View PostI cleaned the already clean IACV, Adjusted the FITV and cleaned itOriginally posted by andrewdink View PostI had the same problem and it was a simple fix. I found the culprit to be the engine idle control valve! When you remove the cap on the top, you will see a probe with a plastic ring around it, and the ring has two flat slots, tighten the ring all the way till it's tight, and just like that problem solved!
#2 what you are referring to is the FITV which he said he has already cleaned and adjusted.
My 5.7 LS1 Holden Ute
