For all with exhaust leaks....
    I just fixed my header to downpipe leak today and I wanted to tell everyone that has a exhaust leak FIX IT! As soon as I fixed mine, no lie I felt a difference in performance and the car felt like it drove smoother for some reason.
    PARTING OUT MY 1990 EX COUPE!! EVERYTHING FOR SALE! CLICK HERE
    Listen or download the first 4 songs I completed for my new upcoming album here!!
    My member's ride
    im sure thats what everyone with leaks is trying to do
      Yea, my header is leakin' from the 4th port, where it's connected to the head. It's blowing black smoke onto my valve cover and stuff. Plus, I hit a bump and bottom'd out the front of the car, and put 2 dents in the downpipe. I'ma just buy a new one. I'm sure those 2 dents in the downpipe are hurtin' me, since my o2 sensor is after the flex. But yea man, exhaust leaks do some damage. Plus, the random raspy sound they make.
      98' Mustang 3V Swap
      11' VW CC R36
        yeah. i have one too., just need a friggin bolt that will fit and a way to get a breaker bar under to torque a coarse thread bolt into it.
          Well some people might put fixing it off for a while because they think it don't affect anything but the sound. The header to downpipe was very easy to fix. I just took off the downpipe, scraped the old gasket off, put a bunch off copper sealant on the downpipe flange and the header flang, waited about 15-20 mins, then put it back together and let it dry overnight. When I but the downpipe back on, I took that metal bracket off the car that holds the downpipe to the frame right before the flex pipe. On my car, this was holding the downpipe on a angle so the flanges were not sitting flush and thats what caused the leak and blow out. Here are some pics:
          Shit ebay gasket lasted about 2 weeks.
          My fix
          Problem solved and was free because I had some copper sealant laying around
          My member's ride
            you might wanna put that bracket that holds the dp to the engine. overtime you going to have problems with the flange.
              yeah i wish that would fix mine but i already know where it is leaking from and thats not gonna do it. im getting it fixed soon hopefully
                mmmmmm peanut butter
                www.stl-imports.com
                Referral: crx08
                support the import community
                  My leak is right before the muffler. the sound is terribleI need new everything!!
                    If i put the bracket on, right now i will have problems with the flange because it will pull the downpipe down more then it should be. I might fab up a plate and drill some holes and slap that on in a couple days.
                    My member's ride
                      Is it on a straight section of pipe? If it is, a quick fix you can do to temporary stop the leak is cut both ends off a soda can and then slit from top to bottom on one side. slide it over the leak and use 2 hose clamps to tighten it down. It won't last forever but it will help until you get it fixed the right way
                      My member's ride
                        Depending on where the exhaust leak you will lose power. Its just noisy the only thing I see. I had a leak in my piping before the muffler.
                          ill be doing this soon
                            thats one way to biuld post count, its also a way to piss off the mods.
                            man, you sure know how to lay a bead! Do my bath tub surround?
                            you'll love my nuts!
