I going to be doing a transmission fluid change on my 93' prelude SI (166k miles, yes it’s an auto tragic). The car runs fine but has a hard shifts and from all of the other issues and poor maintains I had to correct from the previous owner I have no clue how often or with what fluids they changed the transmission with. The plan is to do the normal drain/refill then "flush" the old fluid out of the torque converter while filling the trans with fluid at the same until only clean fluid comes out, top it off an call it day. Now when it comes to oil I would rather not pay stealership prices and have been looking to "aftermarket" options and looks like everyone is a fan of either Valvoline Maxlife or Castrol Transmax when compared to
-Honda atf "DW-1"(Density 0.85 g/cm3@15°C; Viscosity @40C= 25.09 cSt; @100C = 6.835 cSt),
-The Castrol has a higher viscosity rating @ (Viscosity @ 40°C= 36.6 cSt; 100°C= 8 cSt.)
-Valvoline ratings (Viscosity @ 40°C, cSt 28.18, @100°C, cSt 6.11; )
Since I am in Texas we have brutal summers and would assume that an oil with higher viscosity ratings would be best for me, as the hotter the oil gets the thinner it gets, leaded to fast wear. Does anyone have any experience with using Castrol transmax or Valovine max life? Also anyone use additives to their oil for smoother shifting/ wear reduction.
