My car's leaking oil and it's getting really annoying... I have to put cardboard under the car if it's gonna sit for more than a few hours cause it leaves a decent sized pool under it if it sits for a while.
As far as how much it leaks, maybe it goes through a quart in about a week or a little more, I don't really watch it that close... It's not like the thing just pours out oil, if I sit by the car and try to watch it drip it does take quite a while between drips, it just adds up after sitting for a day or so
But it leaks whether the car is running or sitting, and the drops seem to be coming from around the back driver's side corner of the engine block. Since this is near all the timing stuff, I was afraid it could be a crankshaft seal or a balance shaft seal, something like that, but I was informed that either of those would almost empty the car in a few hours. So, in all likeliness, is this an oil pan gasket? I know they're a pain to install, so I don't wanna do it if it's likely to be something else.
