Sorry about the delay guys i did end up changing the IACV as you guys recommended but still having the same issue and have not checked the ELD because i'm not sure how to check it or where it is located. I did also change the throttle body from the junkyard but ended up returning it because didn't fix the issue plus mine was in better condition .Too bad i ended up cleaning it for no reason ;/
I forgot to mention in the beginning of this thread that i used seafoam before i cleaned the intake passage and i think this is probably what caused the car to start stalling when getting to a stop light. The car itself got worst now i cant really drive at all because it just wants to stall once i step on the gas pedal or reach about a foot or two of road. I'm thinking of having a mechanic check it out but i feel like it just might be a simple sensor. I had seen this guy in Youtube having similar issue with his 94-96 Accord. He had explained that he ended up changing all different parts like me and nothing worked until he changed The ECU. What do you guys think???
