Originally posted by Size9zombie
View Post
Speedo issues, still....
If you remove fuse #1, is there then 12v at the hot side of the fuse socket? As well as feeding the back up lights, the yellow wire also feeds the MIL indicator light in the cluster which is grounded back to A13 at the ECM.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Originally posted by fleetw00d View PostIf you remove fuse #1, is there then 12v at the hot side of the fuse socket? As well as feeding the back up lights, the yellow wire also feeds the MIL indicator light in the cluster which is grounded back to A13 at the ECM.
<object id="pdfOb" data="http://www.srsplatform.com/webservices/Srs.WebPlatform.WebServices.FileManager.svc/POX/Get?sessionTokenId=4cdcba5b-27b3-44ea-acf7-32c1ef2835b7&project=OemContent&file=oedoc s%5c3946%5cpdf%5ca910706.pdf#page=1&navpanes=0 &zoom=100&navpanes=0&toolbar=1" type="application/pdf" width="100%" height="100%" style="caret-color: rgb(0, 0, 0); color: rgb(0, 0, 0); font-family: -webkit-standard; font-style: normal; font-variant-caps: normal; font-weight: normal; letter-spacing: normal; orphans: auto; text-align: start; text-indent: 0px; text-transform: none; white-space: normal; widows: auto; word-spacing: 0px; -webkit-text-size-adjust: auto; -webkit-text-stroke-width: 0px; text-decoration: none;"></object><object id="pdfOb" data="http://www.srsplatform.com/webservices/Srs.WebPlatform.WebServices.FileManager.svc/POX/Get?sessionTokenId=4cdcba5b-27b3-44ea-acf7-32c1ef2835b7&project=OemContent&file=oedoc s%5c3946%5cpdf%5ca020111.pdf#page=1&navpanes=0 &zoom=100&navpanes=0&toolbar=1" type="application/pdf" width="100%" height="100%" style="caret-color: rgb(0, 0, 0); color: rgb(0, 0, 0); font-family: -webkit-standard; font-style: normal; font-variant-caps: normal; font-weight: normal; letter-spacing: normal; orphans: auto; text-align: start; text-indent: 0px; text-transform: none; white-space: normal; widows: auto; word-spacing: 0px; -webkit-text-size-adjust: auto; -webkit-text-stroke-width: 0px; text-decoration: none;"></object> Just a couple of pieces of information from the Honda Tech articles
Originally posted by CB7Xhris View PostIma check that. I'm no pro when it comes to wireing lol. I did finually check my CEL today and its a code 17, vss issue. But I KNOW the vss is good as ive put it on my other CB and it works fine, plus its brand new90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
a 12volt power distribution wire that is showing low voltage at the fuse panel output and the 12volt input is ok, 100% the problem is at the fuse box, if not internally burnt,there is a loose connection/connector on it somewhere.
The connectors have a type of dielectric grease on them from the factory, over the years this grease breaksdown and actually starts being conductive and does odd things with the electrical system, aftermarket alarms and stereo systems that are wired\spliced directly into the fuse panels cause all sorts of electrical issues. Im in So. Calif. and see this at least once a month, even on newer cars and not only Hondas. Honda has released multiple service bullitins over the years regarding fuse panel issues and after market wiring,so the above statement saying these rarely fail is completely untrue,alot of failures have to be reported(warranty work)for a TSB to be issued by a MFG. the gunk in the photos is the factory dielectric grease breaking down and spreading over time, a thick layer of this on a connector will also cause issues,clean it all up and good to go. All this stuff generates excessive heat, big no no with electrical componets,
one thing to remember with aftermarket electrical componets like alarms is, just because its been installed that way for years don't make it the right way!
electrical repairs\installs should not have those POS quick lock\crimp connectors installed, connections and splices should be soldered, PERIOD!!!
