I need help with crank pulley (harmonic balancer). I start up my car and let it warm up. Then when i go to turn on my ac, the crank pulley starts to wobble. i check to see if the crank pulley bolt is tighten. and yes it was. Anybody have had this kind of experince?
please help with crank pulley
i havent had a problem like this, but its sounds as if your bearing might be mangled, are you leaking oil?http://www.cb7tuner.com/vbb/showthread.php?t=167601 Click to see my new ride
The rubber balancer gets old with age and causes the outer pulleys to wobble.
Replace it
My 5.7 LS1 Holden Ute
Yep, you need to replace the balancer pulley.....if you don't have a GOOD (powerful) air impact wrench you'll need the crank pulley holding tool: hereMy Member's Ride Thread
