I'm really needing some help and some questions answered. Car is running horrible. Done a H22 swap. Thinking I might need a p28 ecu. I have the stock ecu that I got with the engine.
Having some problems with my car
Stock ECU will not run an H22 well at all, looks like you already know the answer to your question.1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
If your H22 isn't running good with the p13 ECU, then you should consider getting getting tuned with a p28 ECU. You could get street tuned and the p28 chipped which would be better than a custom basemap, but if you wanted to do it the best way in my opinion would probably be to tune it on the dyno with some type of engine management software like Crome, Neptune, or Hondata.
Originally posted by mighty mouse View PostI'm really needing some help and some questions answered. Car is running horrible. Done a H22 swap. Thinking I might need a p28 ecu. I have the stock ecu that I got with the engine.
A little more specific might aid in getting a little more detailed help.
In Need of an engine, just a basic f22a...pm me if you have one willing to part with.
Oh I thought he was using a pt3/pt6. When you bought the motor did you freshen it up before the install? Any chance your mechanical timing is off? Did you check all grounds and vacuum lines?1993 SE Coupe MRT - 1992 LX Sedan MRT
Well he/she never did say which ECU they were running so if it is the pt3/pt6 then I'm sure even going to the p13 ECU would help somewhat. Hard to say what the problem could be without specifics. Check all your sensor/connectors and make sure they're plugged into the right ones. Do you have any check engine lights?
