I put my car on jack stands today and looked underneath car for my engine harness grounds. I could find none. I was mostly looking while directly under oil filter and anywhere else i could see a wire harness. I found no grounds at all. Where the heck are they at? Are there any engine harness grounds down there. From my diagram it looks one comes of near ps pressure switch but i could not find it.
Where are the engine wire harness grounds?
Your only engine wire harness ground is under the thermostat. You then have separate grounds one from valve cover to driver side mount, one from transmission to battery negative. That’s it.~Nick~
Originally posted by Grumpys93 View PostYour only engine wire harness ground is under the thermostat. You then have separate grounds one from valve cover to driver side mount, one from transmission to battery negative. That’s it.
Originally posted by Raf99 View PostDon't forget about the underhood fuse box ground (which is under the fuse box)
