Go Back   CB7Tuner Forums > Beginner forum -- New members post here! > Beginner Appearance
Old 08-26-2019, 05:37 PM   #1
Chrisvanoverjr
Newcomer
Chrisvanoverjr is cool... so far.
Interior color change
So my door panel fabric is just about all the way peeled away, from life I guess. My question is, has anyone rewrapped the doors with any types of aftermarket materials? I am strongly leaning towards a carbon fiber material and also vinyl painting the panels black. They're tan now. Any tips or advice would greatly be appreciated.
Chrisvanoverjr is offline   Reply With Quote
Old 08-26-2019, 07:23 PM   #2
deevergote
Don't call me dude.
deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool... deevergote . You'll never be this cool...
Send a message via AIM to deevergote
My friend reupholstered his door panel inserts using cloth and upholstery glue.
The vinyl/rubber/plastic/whatever portions can probably be rewrapped easily enough. I think I’d probably go with vinyl wrap rather than paint.
Interior paints have usually not produced satisfactory results around here. Maybe products have improved, or maybe the the people doing the work didn’t do proper prep work (the key to good paint work.)
Another option is to source oem black interior parts. 91 SE sedan models with Solaris Silver paint had black interiors (with leather). 90-91 Phoenix Red DX coupes have black interiors (cloth... DX is base, so they also have crank windows, meaning there’s a hole for the crank on the panel.)
__________________
deevergote is offline   Reply With Quote
Old 08-27-2019, 12:22 PM   #3
fleetw00d
Contributing Member
If just fabric insert is the problem, it can be replaced with about anything you want. If can find a set of SE leather inserts, it is an easy install. I used the SEM vinyl paint on mine and it has held up very well.
http://www.cb7tuner.com/vbb/showpost...78&postcount=9
__________________
I'm down to one CB, going through withdrawal DTs
90 LX 4dr 5 spd 383,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
07 Element EX AWD 189,000 - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=210623
INVENTORY REDUCTION! LOTS of CB7 parts - you need it? you can have it. http://www.cb7tuner.com/vbb/showthread.php?t=192583 or watch for banner ad at upper right
Old 09-11-2019, 01:09 PM   #4
BreckAConner
CB7tuner Member
BreckAConner is cool... so far.
I was looking at member's upholstery job a while back on the forum, he said something about a thinner I think on the vinyl to make the paint stick better? If it's easier than that, I'd like to try it as well.
BreckAConner is offline   Reply With Quote
Old 09-11-2019, 05:20 PM   #5
fleetw00d
Contributing Member
Quote:
It is not a thinner, it is an adhesion promoter - sprays on like the coating, then you spray on the coating before the adhesion promoter dries.
