hey...I lost my rocker arm locations...are there any issues I'm going to run it to...I figure I should take is easy the first few 100 miles so that the arm can wear into there new locations
*UPDATE*
Got the block back, put on the tensioner, lower crank gear off f22b,f22a water pump,swithced out the oil pans......On the head side; I got all valve stem seals replaced,Oem valve guides,Oem valves,Oem cam seals, Bisi dual titanium vavle springs, Bisi cam gears, and the 2.4 Bisi cams
Oh my gawd, your build is hot. That motor looks so amazingly brand new. I'm super jealous. Been watching this one for a bit now, figured I'd comment. Keep it up man, can't wait to see it in and get some numbers!
*UPDATE*
Thankyou guys for all the great comments AS of today its been fully tuned. Took 4 hours of tuning @ KiazenSpeed, Ried Lunde (owner) was the tuner.
At 13.5psi - Old setup, tuned - 312whp and 294wtq
At 13.5psi - no tuning just base run - 343whp and 319wtq
At 16.5psi - tuned - 432whp and 364wtq
At 17.5psi - tuned - 457whp and 376wtq
At 20.5psi - WILD tuned - 490whp and 394wtq!
Didnt get to fully tune it, the manifold wouldnt hold boost. It hit 20.5psi for 1 sec. at redline 7800!
Rev limiter is set at 7800rpm!
The HP graph, Old vs New
your build is identical to what i am doing right now except the cams, speaking of the valve train how much did it run you because i was planning on using brian crowler b18 valves and springs but total it cost 330 or so just curious
wonderous minda try to persue why I have never seen this thread.
great work, truely inspirational, now I just need to save money.
in that vid where your adjusting timing on your dizzy, is that joser in the background?
Nice build! You really picked up A LOT of power going from 13.5 to 16.5 psi! Impressive numbers. Is your head or IM ported? I didn't see you mention that anywhere.
