Hey guys ,
im in need of some help . my car just randomly did not want to start . does not crank over at all !
i pulled out the switch and tried to manually turn it with a screw driver and nothing !
so i ordered another ignition switch from Rock Auto .
i put it in . and after 3 turns of the switch nothing . then all of a sudden it cranked right up . left it on for a few minutes . turned it off . went to turn it back on and nothing again . now it will not turn back on at all !
could this be another bad ignition switch or is something else causing the problem ?
