just wondering is there a way where i can put a kill switch on my car so no one could really steal my car just a quick ques?!?!?!
kill switch
Your car needs fuel, air, and spark... plus the signal from the ignition switch, battery, and ECU... to run.
Intercept one of those, and the car will not start. Get creative, and don't share it with anyone. Posting on a public forum that you're rigging a killswitch, and asking how it's done... that's only inviting a thief to come take your car.
cp[mike] and I were discussing a hidden magnetic switch located under the dash, and activated with a magnetic key. A thief would need a proper magnet AND the location of the switch to start the car. I forget which one of us posted the thread. It was MANY years ago... 2003 or 2004. Neither of us followed through (though I know he has the knowhow to do it... I really don't!)
I ran two switches from the ecu and linked them together so thievs would have to hunt for both switches to complete the cycle. A word of advice, dont place the switches somewhere common such as under the seat or the ash tray and hide and wrap all wires into the harness as much as possible. stray wires are a dead give away to where your switch is at.
Originally posted by casterX View Postwhat's the specific name for that magnetic switch? where can i get one?
A switch to the fuel pump is what i went with. Its also confusing for a thief because the car will still crank but never start. The most important thing is locatiion of the switch. Do not put it somewhere obvious or where it can be easily found. Sometimes a second switch, even if its a dummy switch isnt a bad idea. But Dont hesitate to do it either way. Had a friend lose an integra with a 1700 dollar motor in it because he was to careless and procrastinated doing a kill switch. Its the next best thing if you cant afford an alarm. The way i see it: if they break into your car its much easier to replace glass, audio equipment, or personal belongings than it is to replace a whole car... IMO.
Originally posted by protunef22 View PostA switch to the fuel pump is what i went with. Its also confusing for a thief because the car will still crank but never start. The most important thing is locatiion of the switch. Do not put it somewhere obvious or where it can be easily found. Sometimes a second switch, even if its a dummy switch isnt a bad idea. But Dont hesitate to do it either way. Had a friend lose an integra with a 1700 dollar motor in it because he was to careless and procrastinated doing a kill switch. Its the next best thing if you cant afford an alarm. The way i see it: if they break into your car its much easier to replace glass, audio equipment, or personal belongings than it is to replace a whole car... IMO.
Bought from:AbsurdNY,92smokeaccord,cb7inct,nevi325,xkjnboix,cb 7resurrector,JoshM
MRT: http://www.cb7tuner.com/vbb/showthread.php?t=203451
Originally posted by markrutherford View Posti dont know about that lol I paid 500 for my accord and got about a $600 system in it lol
the whole car then would be 1100$.....
Neptune
Neptune software has auto immobilization built in that takes an external input (switch, which is nice for racing and track applications), and also a user defined throttle and break switch combination.
E.G. to turn on your car you could program it to need two presses on the break and one on the gas before the car will turn on. I haven't looked to see the limitations on combinations, but it is enough that a thief would not be able to guess it.
Good software and a nice feature
you can get a push start button from an s2000 i got one in my m3 its preety cool because you got to turn on the ignition then after open the cigarete lighter and push the button... ive seen some where you need a code
Originally posted by pedalpusher90 View Postthats true deev im now thinking of a project like that one of my buddies wired up a push start in his civic
Wow, it's amazing what this forum can do.
Been here a few weeks and now I want a manual, fogs, and a kill switch!
I like the fuel pump idea. What's supposed to go in the cutout on the very end of the headlight stick? I think it'd be neat to put one there.MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
