^ thatd be pretty obvious...
kill switch
What's supposed to go there?
The other place I'm thinking of is under the steering wheel, but I've seen that done waaay to often.
MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
maybee inside the ashtray in the back seat... just a thought
Originally posted by deevergote View PostI have absolutely no idea. It's something I haven't thought about for 5 or 6 years. Look back at old threads created by me or cpmike from 03-04 and you'll find it. I'm pretty sure we put it in the DIY section... not positive though.
it's in the DIY.. thanks
Forgot to mention. A couple years back my friend had a stock cb7 automatic and it wouldnt start unless you put the key in the acc position, step on the breaks and put the left blinker on. dunno if that was a factory alarm setup or not but he bought it like that...kinda like the Neptune system (which sounds pretty cool btw) but not as sophisticated.
A kill switch is GREAT when done right.There are MANY places to hide it where nobody would even look, you just have to get creative.
For example, in my EJ Civic, this is where I put my fuel kill - when you open the passengers side door, there is a plastic cover on the side of the dash that pops out(it is just covering a bolt that holds the dash in place) - that is where my kill switch was. You had to open the passengers door, pop off that plastic cover with a little screwdriver, and then you had access to the switch. After some practice, I was able to get to the switch right from my drivers seat - had to reach over and open the passengers door and pop off the plastic cover with a key. Took some practice but I usually did all of that in 5sec. The switch was wired to the ECU harness that was basically right there. In order to find my wiring, you had to remove the glove box, and really look up there.
Even with that kill switch, I still had other "layers" of security on my Civic.
The only problem with kill switches is that with enough time, they can find your wiring. They don't even have to find the switch itself, they can just rip your interior apart and follow the fuel pump wiring - they will probably find your extra wire.
Also, when they hear that the car isn't getting fuel, they can just run a wire from the fuel pump straight to a power source and BAM they got fuel. With practice, I bet one could do that in a few minutes. So say at 3AM, that will be very easy to do.
Another problem with kill switches is that they can bring a tow truck. And if your car has a shitload of rare aftermarket parts, it could happen.
And the problem with the Neptune ECU security features and/or removing your ECU, is that a thief can swap your ECU in under a minute.
Moral of all this - you need more than one layer of security. Starting with choosing carefully where you leave your car.
after i posted that, im even thinking about doing this lol
Originally posted by stock1990ex View PostRear ashtray sounds like a really good spot. now that you mention it does anyone know where i can get a replacement rear ashtray tas dosn't have it
You could always do what a friend of mine did to his EJ1, 6 switches in a row in the glove box, each had a small led above. To allow the car to start three had to be flipped up, two were dummy switches that only went to the leds and one had to be flipped down(installed upside down on purpose). One went to fuel pump, one went to starter, one went to ecu power, and one went to his MSD coil. He always drove with the dummys and upside down switch down and others up. He was always removing them and switching them around so even if people knew that was how to start the car they wouldn't know the combination.Call me Travis.
2006 Cobalt LS/SC ~ "Burt the Bloody Bumble Bee"
1992 Accord LX ~ "Smoothie"
1991 CRX Si ~ Hellion
1989 GMC S15 ~ Oldie
