Hi folks,
First off, I'm new to the forum. Although I've religiously referred to CB7Tuner, I decided I needed to become a member for some real help.
So here's the scoop:
When I bought my 92 LX with 98k original miles, the owner stated it had a blinking D4 issue. After doing some research, I replaced the main fuel relay and that issue never occurred again. Whew. My CB7 now has 136k.
So up until a few months ago, I never had issues with my tranny again, until I noticed D4 being solidly illuminated upon turning the key in the 'on' position, therefore resulting in the infamous 'limp mode' indicative of faulty TCU components. This issue occurred at a more frequent rate as time went on. I even noticed that, at times, while I was driving around that D4 would flicker in no apparent pattern. I tried pulling codes, and the only thing popping up was D4 continuously lit (faulty TCU or '0', if I understand correctly.)
I replaced my lock-up solenoid that was not clicking properly after applying 12v, and that didn't seem to make much of a difference. I finally contacted a fella on a facebook group who repaired my TCU, which previously had a leaky capacitor. After hooking up the repaired TCU - (all 7 capacitors were replaced), bingo! Drove around town a little while to make sure. In my honest opinion, it shifted smoother than the day I bought it about 3.5 years ago. D4 no longer was lit upon turning the key in the 'on' position - until the next morning.
I proceeded to unhook the negative battery terminal and re-connect it, which at that moment, the D4 light did not appear upon turning the key in the 'on' position. I took out the hazard fuse for about 15 mins for the hopes of resetting the ECU. Drove around town a bit, no issues. Pulled codes; none.
Next morning I turn my key into the 'on' position, and lo and behold D4 is illuminated.
What could cause this to occur? I'm at a total loss since:
1. there are no codes, and
2. unhooking and re-connecting the battery/hazard fuse seems to 'reset' the TCU/ECU
Any help would be greatly appreciated. The parts cannon is locked and loaded, unfortunately. Thank you all in advance!
