This is one of my favorite right ups. Good jod da9b16!
SUSP : 5 lug conversion 6th Gen Accord
da9b16 I did my whole front end using the 01 v6 knuckles and im lowered on koni yellow+neuspeed sport and im having issues with the knuckle rubbing on the springs...are you or anyone else having a similar issue? I made a thread of how to minimize/completely stop it
Originally posted by Uncle WilleyWhen I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
Originally posted by JaberCB7 View Postda9b16 I did my whole front end using the 01 v6 knuckles and im lowered on koni yellow+neuspeed sport and im having issues with the knuckle rubbing on the springs...are you or anyone else having a similar issue? I made a thread of how to minimize/completely stop it
Originally posted by lordojaim with you on that one bro! aint nothing beat free food and drinks any day of the week, even if its at a funeral
Originally posted by nate'sCB7 View PostThis is probably in here somewhere but im lazy and didnt read all posts.
Are the '00 v6 Accord calipers the same or equivalant to VTEC calipers?
i don't know about the equality but
if you scroll up and look at the pics of my front wheel you will see where i used the 02 TL bracket with the 90 Accord caliper, all worked nice
Originally posted by gloryaccordy View PostThat is weird
Are your UCAs new?
01 EX V6 Part# C9476
01 EX Vtec Part# C8101
Im guessing no.
Originally posted by nate'sCB7 View PostI didnt mean are they Exactly the same.
Ok, how about this.
Will the '00 Accord v6 calipers provide similar performance capabilities in comparison to the VTEC calipers?
Originally posted by JaberCB7 View PostI believe their the same design (mechanically) but the V6 might have a slightly bigger rotor and caliper. If you want better performance Ive heard of members using the Acura Legend calipers witch uses dual pistons
But because the Legend calipers are a rear mount style (cb7 calipers are on the front of rotor)
with the dual pistons, the larger of the 2 would be on the bottom which doesnt allow full contact of the top piston.
Unless you can mount them on the opposite side, of a CB. Hopefully that made sense....
yea it does but it mounts in same place calipers is just bigger best to use 95 legend g,s brake setup they have bigggggger calipers and rotorsOriginally posted by deevergoteThis thread is over a year old, you fucking retard.
I really don't think all that trouble is worth it though
My friend had a 2002 Altima 3.5 SE which weighs like 300-400lbs more than a CB... all he did was upgrade the rotors + pads, and that thing stopped on a dime from like 120MPH back to back to back
Prelude caliper/rotors are the same size up front... u get Brembo blanks + nice pads... u don't need much... and u dont have to worry about calipers.
you can mount the legend caliper with the bleeder valve down and how its supposed to mount (but on our cars), and when it comes time to bleed it, all you need to do is remove the lower bolt holding the stuff in, loosen the top bolt, swing it up, stick a spare rotor or something solid in there to act as a rotor, and bleed normally.
mounting bleeder up will make it convenient, but it won't take advantage of the different sized pistons, IIRC.
