DANGER !!!!!!!!: Guys I am one of those unlucky people in life and I could really use the support as quick as possible !! I'm F***KED ...well nothing wrong with the rocker arm assembly yet !! ... the problem is that I lost a 10 mm socket in the engine bay when I was torquing the bolts so I started searching for it to continue my work, suddenly my hand hit the below and the cap came off quickly, after an hour or so, I managed to locate the cap but I don't know if it is missing something I fitted the cap by mating the holes both on the base and the cap ... what is it used for ?!!? it has 2 vacuum hose disconnected !! .... where do they fit ??!!!! HELP !!
I also noticed while searching the following with a disconnected vacuum hose attached to it and laying on the beam ==> what is it ?! and what is it used for, where does it fit, is it important !!! .... I am stopping all work on the rocker arm assembly and I am waiting for your feedback
its back side:
its back side:
