My 92 Cb Idles Is Off Or Something Becuase When I Turn It On It Goes Mmmmm Mmmmmmm Mmmmmmm Mmmmmmm Mmmmmmmmmmmm Mmm And Then Dies And My Gear Changer Gets Stuck In Park
Transmission Help ?
If the idle revs up and down when first started, then settles down once the engine is warm: http://www.cb7tuner.com/vbb/showthread.php?t=206012
There is an interlock on the shifter that requires you to step on the brake before you can move it from park. Do you hear a click under the shifter when you step on the brake pedal? How do you get it out of Park? If you use a key (a small screwdriver will do), put it in the little slot on the right side of the shifter base plate to release the lever; does the lever operate normally once released?90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
