Originally posted by liquidoblivion
View Post
Question about solenoids and the infamous D4 flashing light...
Try swapping a reman TCU in. You might not have fully repaired the TCU.1993 SE Coupe MRT - 1992 LX Sedan MRT
93 Accord SE Bose Stereo MYTHS & FACTS - F22A* Power Plant Removal(UNDER CONSTRUCTION)
Main Relay, Guaranteed.
Cheap and free way to test.
You have D4 Light and/or CEL and car only turns over.
Step 1: Turn the key back to the off position.
Step 2: Locate your main relay (under your driver side dash)
Step 3: Knock on your main relay. (Just tap it with a screw driver or something)
Step 4: Turn the key two clicks and watch as your CEL and D4 light have disappeared.
Step 5: Replace main relay.
I battled this problem for a year or two. Luckily i live in Oregon and its cold most the year but summer time i'd have to leave early for work all the time just cuz i never knew if id get this error code and not be able to start. I replaced the solenoids (and i had the exact same codes as you) but it didn't change the CEL or D4 light. Turns out the main relay (more than likely if its not the OEM one) has very cheap soldering and with the higher temperatures outside causes failure. The aftermarket replacement main relays are made very cheaply. They use a method of soldering called wave soldering. Basically mass production soldering. Defiantly gives you quantity over quality.
But yeah hope that helps someone if not you. Lol i know its a late post but i came across this and had to say something cuz i fought this forever and no where did anyone send me in the direction of the main relay.
