** Note: This thread is for any F22ax NA engine build that satisfies the following requirements. Must have performance enhancing modifications to the cylinder head and/or block to be on this list. Full qualifies as both head and block modified, mild being only the head. **
F22AX NA - FULL BUILDS:
Bisimoto: Honda Insight
- Head: F22ax, ported
- Camshaft: Bisimoto F22ax level unknown, hardweld
- Intake: dual stage fuel injection individual throttle bodies
- Exhaust: Bisimoto F22ax race header
- Stroke: 95mm
- Bore: 90mm
- Static Compression: 17:1
- Fuel Type: race gas
- Engine Management: AEM EMS
- Main powerband: 10,200 RPM shifts
HondaFan81: 1991 Accord EX
- Head: F22ax, CHR Motorsports Ported
- Camshaft: Bisimoto F22ax level 3, hardweld
- Intake: BPi velocity stack, 3" short-ram, 74-69mm throttle body, ported & modified H23 intake manifold
- Exhaust: Bisimoto F22ax street header, 3" exhaust system
- Stroke: 95mm
- Bore: 86mm
- Static Compression: 12:1
- Fuel Type: 93 octane, pump
- Engine Management: Hondata S300
- Main Powerband: TBD
Accordtyper91
Dyno Numbers: 182whp 174wtq
- Intake: Ported H23 manifold with ported TB
- Injectors: Dsm 450cc
- Block: F22a1 with Kazinspeed balance shaft eliminator kit
- Crankshaft: F22a knife edged and balanced
- Pistons: Bisimoto 10.5.1
- Rods: Bisimoto H-beam
- Camshaft: Bisimoto stage 2
- Valve springs: Kms racing
- Retainers: Kms Titaniun
- Valves: Kms 1mm oversized SS valves
- EMS: AEM Stand alone
- Exhaust: Dc sports header, custom 2.75 exhaust with N1 muffler
93Accord
Dyno Numbers: 176whp 142tq
- Intake: Generic short ram intake
- Manifold: Extrude hone A6 manifold
- Injectors: 50lb/hr injectors
- Head: F22a, Ferrera valves
- Crower Dual valve springs
- Crower titanium retainers
- Camshaft: Delta Regrind
- Pistons: 12.5 Wiseco Pistons
- Rods: Crower Rods
- Block: Darton Sleeves
- Exhaust: Kamikaze Header
- Engine Management: AEM EMS Tuned
F22AX NA - MILD BUILDS:
jdm92_accorn: 1992 Accord LX
- Head: F22ax, Bisimoto Port
- Camshaft: Bisimoto F22ax level 2, regrind
- Intake: EBay short-ram, ITR throttle body, H23 intake manifold
- Exhaust: EBay header with 2.25" collector, EBay 2.25" exhaust system
- Stroke: 95mm
- Bore: 85mm
- Static Compression: 8.8:1
- Fuel Type: 87 octane, pump
- Engine Management: chipped P06 ECU
- Main Powerband: 2300-6800 RPM
Karl: 1990 Accord LX
- Head: F22ax, stock
- Camshaft: Bisimoto F22ax level 2.5, hardweld
- Intake: ITR throttle body, H23 intake manifold
- Exhaust: DC header with 2.5" collector mod, 2.5" exhaust system
- Stroke: 95mm
- Bore: 85mm
- Engine Management: chipped ECU, Crome tuned by RLZ Engineering
- Main Powerband: 5000-7500 RPM
F22Turbo702: 1990 Accord EX
- Head: F22ax, gasket-matched intake and exhaust ports
- Camshaft: Delta F22 272, regrind
- Intake: short-ram, F22B DOHC throttle body and intake manifold
- Exhaust: DC header, 2.5" exhaust system
- Stroke: 95mm
- Bore: 85mm
- Fuel Type: 91 octane, pump
- Main Powerband: 4000-6800 RPM
HondaFan81: 1991 Accord DX
- Camshaft: Delta F22aax 272, regrind
- Intake: 3" short-ram, 67-64mm H23 throttle body, ported H23 intake manifold
- Exhaust: Kamikaze header, 2.5" exhaust system
- Stroke: 95mm
- Bore: 85mm
- Engine Management: chipped P06 ECU, Hondata S200
- Main Powerband: 4000-7000 RPM
Application: Drag Racing
Dyno Numbers: HP 455, TQ unknown, Dynapak
- Block: F18Dyno Numbers: HP 455, TQ unknown, Dynapak
- Stroke: 95mm
- Bore: 90mm
Application: Street, Occasional Track
Dyno Numbers: TBD
- Block: F22axDyno Numbers: TBD
- Stroke: 95mm
- Bore: 86mm
Accordtyper91
93Accord
- Rods: Crower Rods
Application: Street, Daily-Driver
Dyno Numbers: HP 171, TQ 159, Dynojet
- Block: F22ax, stockDyno Numbers: HP 171, TQ 159, Dynojet
- Stroke: 95mm
- Bore: 85mm
Application: Road Racing, NASA Honda Challenge H2
Dyno Numbers: HP 161, TQ 137, Dynapak
- Block: F22ax, stockDyno Numbers: HP 161, TQ 137, Dynapak
- Stroke: 95mm
- Bore: 85mm
Dyno Numbers: HP 157, TQ 142, Dynojet
- Block: F22ax, stockDyno Numbers: HP 157, TQ 142, Dynojet
- Stroke: 95mm
- Bore: 85mm
Dyno Numbers: HP 152, TQ 127, Mustang Dyno
- Block: F22ax, stockDyno Numbers: HP 152, TQ 127, Mustang Dyno
- Stroke: 95mm
- Bore: 85mm
__
