something broke under the dash, peices of plastic on the floor, brake lights stuck on ??????? just happen like 4 mins ago
brake lights
Look like a shattered blue sucker?
That rubber/plastic piece goes on the back side of the upper portion of the brake pedal. It hits a switch that activates/deactivates your brake lights.
Get up under there (you'll have to put your head on the floorboard) and put a nut/bolt where the platic piece broke from. You'll never have to worry about it again.
Originally posted by visualpoet View PostDo you have pieces of plastic, maybe a spring and a couple of brass colored metal things? Without seeing it, I'm guessing the brake light switch broke.UNDERGROUND SOCIETYNEW COUPE MEMBERS RIDE THREAD COMMING SOON
you mean just ram it into the spot ????UNDERGROUND SOCIETYNEW COUPE MEMBERS RIDE THREAD COMMING SOON
Originally posted by 1990Ex View Postyou mean just ram it into the spot ????
The plastic piece fits into a hole on the pedal. Get a bolt that will fit in the hole.
Just make sure the bolt isn't too long.
Originally posted by JoshM View PostBolt head towards your seat, nut holding it onto the pedal from the engine side.
Just make sure the bolt isn't too long.UNDERGROUND SOCIETYNEW COUPE MEMBERS RIDE THREAD COMMING SOON
Originally posted by visualpoet View PostGood looking out, Josh! I figured the switch broke somehow, but luckily you've had the problem before!
Originally posted by 1990Ex View Postthx bro, its at the top of the brake petal correct ??
Hardest part of install is getting yourself back out of the car.
Originally posted by visualpoet View PostGood looking out, Josh! I figured the switch broke somehow, but luckily you've had the problem before! Excellent advice on the fix, as well! I'm giving you a prop on your reputation!UNDERGROUND SOCIETYNEW COUPE MEMBERS RIDE THREAD COMMING SOON
