Do you have pieces of plastic, maybe a spring and a couple of brass colored metal things? Without seeing it, I'm guessing the brake light switch broke.
That rubber/plastic piece goes on the back side of the upper portion of the brake pedal. It hits a switch that activates/deactivates your brake lights.
Get up under there (you'll have to put your head on the floorboard) and put a nut/bolt where the platic piece broke from. You'll never have to worry about it again.
kinda like a small cone shaped peice of plastic, ill grab a pic
exactly what i did.happened to me a few months ago. rubber piece came out. killed my battery too. so i just got a nut/bolt combo and boom. fixed.
Bolt head towards your seat, nut holding it onto the pedal from the engine side.
The plastic piece fits into a hole on the pedal. Get a bolt that will fit in the hole.
Just make sure the bolt isn't too long.
Good looking out, Josh! I figured the switch broke somehow, but luckily you've had the problem before! Excellent advice on the fix, as well! I'm giving you a prop on your reputation!
