239whp 192wtq
Engine/ Exhaust
1995 Jdm H22A
T2W4 Transmission
ESP Traction Bar
Hondata S300 p28
Skunk2 Pro1 Series Cams
S2 adjustable cam gears
S2 Pro Series valvesprings
S2 titanium spring base & retainers
HyTech header
ARP Studs
Innovative motor mounts (75A)
Comnetic .051" HG
AEM Uego wideband O2 sensor
H23 manual tensioner conversion
EuroR IM (portmatched)
Omni 70mm TB (portmatched)
Rosko Racing fuel Rail
410cc RDX injectors
Exedy Stage 1 clutch
Competition Clutch Ultra-lightweight flywheel
Hondata IM gasket
4" BLOX velocity stack w/ K&N filter
AEM V2 Dual Chamber Intake
3" Kteller exhaust
Magnaflow muffler
Ngk ignition wires; Ngk plugs
odyssey battery (relocated to trunk)
PS delete
Wheels/ Suspension
SSR Professor Sp3R SBC 17x8 +24
215/40 Falken Azenis rt-615k+ tires
Function Form Type-2's
FFC lower control arms/toe arms
Suspension Techniques Front Sway Bar
ST Rear Sway Bar
Prothane bushings total kit (Black)
ROH conversion
11.1 Power Slot cryo treated rotors
NSX calipers
rear disk swap- powerslot rotors
Hawk brake pads
BB4 prelude brake master cylinder
BB4 brake booster
4040 prop valve
DC rear upper strut bar
No name front upper strut bar
Exterior
PPG Navajo Red paint w/ hint of crushed glass and mirror
Jdm 92/93 2-piece headlights
Jdm foglights w/ Lexus yellow caps
Lexus RX330 projector retrofit
e46-R shrouds
5000k d2s bulbs
35W morimoto ballast
Sarona rear visor
AVS window visors
Prontry front lip
Gsquare replica grill
92/93 sedan trunk swap
Red/clear tails
OEM flushmount spoiler
Shaved antenna and emblems
3M Tint
Interior/ Audio
Custom Black/ Tan interior
Black suede headliner
Custom door panels
Sparco steering wheel
NRG quick release w/ lock
DC shift knob
BB4 shifter (Love it!)
Alpine CDA 9813 Hu
Mb Quart components
1 JL Audio 12W7
Mtx 18000/1 amp
Future plans
boost?
Brakes!
Different wheels
Yes sir, yours has the better paint though, but I have some plans for this one. Thanks Yall
