Hey all, I was wondering if you could help me in this little project we're gonna get started here. a lot of members on this site have been asking what seats work in the CB7. Yes, there is that thread with the seats that work, but it only showcases what people have gotten to fit, and only a few of them have the fitment issues discussed. Some answers are out there, but again, there scattered and even the answers sometimes are unsure of themselves.
As a result, I'd like to ask for the help of all the fellow members here on CB7tuner to help compile an ORGANIZED list of seats that can swap into the CB7. Since the main concern of the questions i see that are asked are whether or not the seats suggested can just be bolted in or if they need to hack or in some way modify how the seats are mounted (particularly the seat rails, or whatever they're called), the proposed list organization method will be separated by what can directly bolt into the cb7 (minor swapping of parts from the cb7 onto the new seat to make it bolt up will be included in this category, as long as they are simple swappable parts) and what would need modification of the rail system or whatever (modifying the rails, drilling new holes, welding, the more involved stuff).
PS: one particular concern i also came across was involving coupe rear seats. the rear seat is different from the sedan seats, so please be sure to note whether or not the seat must be from a coupe or sedan version of the donor car to fit into either the cb7 coupe or sedan.
For example, and i'm probably wrong with this but its just for clarification, you will need the 5th gen rear seat off a COUPE to replace the cb7 COUPE'S rear seat.
so... in the list please note
*EXAMPLE*
COUPE rear
1) 5th gen accord/94-97 accord COUPE rear
so the format for the entries will go:
1) (Year, Generation) (What car) (Sedan or Coupe) (Front or Rear)
*SO HERE'S WHAT I NEED YOU TO DO: I will do my best to regularly check this post, and i ask that whoever has done a successful seat swap that you reply to this post with an entry in the same format as above. This entry i will edit into the seat swap list. You may also choose to include pictures as well and I will put those up in the list as well, as visual reference. And for those who will read the thread, you may also provide some details into how you went about installing it, the process you took. So there will be the list as a general overview, and YOUR POST as a detailed description of the seat and how its gonna work. Please keep questions about what seats fit in the CB7 to a minimum, because I am doing this thread to ADDRESS THAT PARTICULAR QUESTION.
PSS: For seats in the "requires modification" list, those of you who will be creating an entry for this section, please provide a general description/list of what needs to be done to get it to work (this will be put alongside the seat in the general overview list), and then in your post provide a detailed description of the process.
PSSS: I remember reading that the acura legend seats, i forgot what year, only a couple of the bolt holes line up with the cb7. please note this in your reply, since I want to make sure people know that this seat doesn't bolt in all the way. I will include this seat in the "bolt-on" section, but I will also asterisk (*) it just to make sure people are aware of this issue.
YOU ALL READY!?!?!? LET'S DO THIS!
SEAT SWAP LIST: COMPILATION OF SEATS THAT WORK IN A CB7
Bolt-On: This section includes seats that can be swapped directly and securely into the cb7 with little to no modification. The seat can be installed into the car without having to modify the seat rails or drilling new holes for new mounting points. Minor swapping of parts, such as brackets may be necessary, and will be noted next to the seat.
Seats marked with an * are seats where not all the mounting holes line up, and are only bolted in by a few bolts. You may choose to bolt these up with only a few bolts, or figure out a way to mount them securely, by drilling new mounting holes. Install these at your own risk.
FRONT SEATS
SEDAN Front
1) 91-95 Acura Legend Sedan/Coupe Front*
- Note from member, TheNextEpisode:
You may choose to wire up the electronic parts of the seat as well. Here is the DIY which covers both installation and the wiring.
http://www.cb7tuner.com/vbb/showthre...gend+seat+swap
*note from me: these do actually require some drilling, but i feel it is straightforward enough to merit being in here. no bending of metal, just drilling straight down for the new holes. the DIY will explain more.
2) Acura Vigor Sedan Front
3)
COUPE Front
Acura Legend COUPE front seats would be preferrable for the coupe, due to the mobile-passenger-seat for rear passenger entry/exit. You may choose to wire up the electronic parts of the seat as well. Here is the DIY which covers both installation and the wiring.
REAR SEATS
SEDAN Rear
1)
2)
3)
COUPE Rear
1) Acura CL 97-99 Rear *NOTE: Seat cushion can be installed securely. backrest is pressfit only, otherwise modding will be necessary*
2)
3)
Requires Modification: This section includes seats that can be swapped into the cb7 with heavy modification. Heavy modification includes, but is not limited to, modifying the seat rail system (cutting, bending, stacking the new seat rail onto the old seat rail...?, etc.), drilling multiple new holes for mounting points, and welding things.
FRONT SEATS
SEDAN Front
1) 90-93 Acura Integra Front
- Note from member, Noxidea:
remove seat belts and replace it with the seat belt receiver from your accord seat (2 Bolts)
Cut off the mounting spots on the Integra seats so there is nothing but seat rails
Cut the mounting hole flanges off the bottom of the accord seats,
Put the Integra seats into the car and center them on there tracks,
Tack weld the Accord small flanges onto the Integra seats in the proper places
Throw some bolts in to make sure they all line up,w
Pull the seats out and finish off your welds,
Bolt the seats back in and check it out
2) 92-96 Honda Prelude Front
Link to DIY: http://www.accordinglydone.com/forum...ead.php?t=8803
3)
COUPE Front
3)
REAR SEATS
SEDAN Rear
1)
2)
3)
COUPE Rear
1)
2)
3)
*EXAMPLE*
COUPE rear
FRONT SEATS
SEDAN Front
3)
COUPE Front
REAR SEATS
SEDAN Rear
1)
2)
3)
COUPE Rear
2)
3)
FRONT SEATS
SEDAN Front
3)
COUPE Front
3)
REAR SEATS
SEDAN Rear
1)
2)
3)
COUPE Rear
1)
2)
3)
i was a little unsure if it worked like that or not.
