1997 H22A (closed deck)
First off, here are the sites I found the best deals at, for those wanting to shop around for savings...
> Euro Export Inc.
> Explicit Speed Performance
> HELM Inc.
> H Motors Online
> Import Replacement Parts
> JHPUSA
> Kteller
> Majestic Honda (OEM parts)
> Race Engineering
> Real St. Performance
> Summit Racing
And of course it never hurts to check those prices against eBay; just be sure to match part numbers and look into the seller's reviews and reputation for not selling knock-offs.
ELECTRONICS
- Hondata S300; Phearable base map for start-up
- RyWire VTEC sub-harness
- AEM gauges: UEGO, EGT, oil press., fuel press. (still plan to get oil temp)
*Future custom dash gauge cluster to include volts & oil temp; that whole set will be by one, different, brand*
AIR + FUEL
- K&N Apollo intake system for 70mm pipe
- AEM 70mm OD aluminum tubing for custom intake
- Professional Products 68mm Power throttle body for ITR, polished
- H22 Euro-R/Type-R intake manifold prepped by Rosko Racing (68mm port match)
- Hondata thermal intake manifold gasket
- Walbro 255lph pump w/install kit
- Rosko Racing rail
- Acura RDX 410cc OE injectors & pigtails
- AEM pressure regulator
HEAD
- Ishino/Stone (OEM) top-end gasket set
- ARP head studs
- Supertech machine hardened valve locks
- Supertech titanium spring retainers
- Supertech 79lb valve springs
- Supertech valve seals
- GSC Power-Division valve guides (Supertechs weren't gripping the seals well)
- Supertech black nitrided dish valves
- New OEM valve spring seats
- Skunk2 Pro 2 cams
- Skunk2 Pro Black Series cam gears
- OEM manual timing tensioner conversion kit
- Skunk2 cam seal
- Skunk2 "Skunk2 Inside" VTEC solenoid cover
BLOCK
- Fel-Pro complete bottom-end gasket set
- Wiseco 11.5:1 pistons (re-sleeve, of course; one of my stock bores was scratched)
- Eagle H-beam rods
- ARP main studs
- ATI street damper
- KS Tuned manual timing tensioner & Walk Blocker
- K-Tuned oil pressure sensor adapter (to 'T' in oil psi gauge)
- S2000 oil filters (part no. 15400-PCX-004)
- ESP traction bar
EXHAUST
*I have a Spoon header that I'd like to compare to the PLM below on the dyno, but since it bolts to the stock downpipe, I'm thinking of having a full custom downpipe made rather than cobbling together a 2.5" collector conversion on the stock dp. We'll see how that works out in terms of timing; it may or may not happen right away, but I do want to see how the headers compare. Also, I am aware that the KTeller exhaust kit is for the sedan/coupe with its more inset muffler location. I actually prefer the look of that, so rather than modify it to fit the wagon location, I will be swapping a coupe/sedan rear lip onto the wagon.
Short version: exhaust is 2.5" from header to just before the first 90* bend, where it steps up to 3" to maintain flow.
- PLM 4-2-1 header
- Vibrant 1197 EGT bung, stainless
- Vibrant 10355 merge collector, stainless 2.5"
- Vibrant 60804 "turbo" flex pipe, stainless 2.5"
- Vibrant 1194A O2 sensor bung x2, stainless
- Vibrant U-J scrap bends, stainless 2.5"
- Summit Racing 4' scrap straight, stainless 2.5"
- Catco 6906 cat, stainless 2.5"
- Vibrant 2.5" bottle resonator x2
- Summit Racing 2.5" V-band connections x3
- Vibrant 2630 2.5"-to-3" transition (exhaust expands to 3" just before the first 90* bend to keep flow up)
- Kteller 3" stainless/mandrel piping
- Vibrant Street Power muffler, 3" in/dual 3.5" out
. It's a very long process, but I don't think I'll ever want to get rid of my Accord.
... But since ur replacing the exaughst and going with ketteller exaughst system I reccomend the 3" unless of course it outragously spensive :P
