Tools needed:
Pressurized air
Pressure gauge
Each tire must be set to 32 psi. The pressure must be set when cold. I.E. before driving for the day.
Remove valve stem cover and check the pressure.
Add or remove to achieve correct pressure (32).
Repeat for all 4 tires.
Make sure to put the caps back on.
Enjoy your improved gas mileage
Pressurized air
Pressure gauge
