I've been hearing an odd noise. It kind of sounds like when you downshift an automatic into third. But my revs are normal.
I've noticed I can always hear it at 30 mph. My car will also shift about then. My top shift solenoid is leaking, but that's because I took it off to see if I should clean it. I have a small amount of oil remaining in my spark plug wells, but I don't think that's it. It could be an improperly adjusted valve, so I'll check them again in the morning.
Because of the 30 mph, I think it's a bearing. But it doesn't have the same characteristics of the last bearing that went bad.
Any other ideas?
Any other ideas?
