Front rotor-over-hub conversion
    This is the common "rotor-over-hub" conversion listing of parts for our 90-93 Accords.
    98-99 Acura 2.3CL front hub assemblies
    90-93 Accord wheel bearing assemblies
    98-02 Accord or 98-99 Acura 2.3CL front rotors
    90-93 Accord pads (for Akebono or Nissin front calipers)
    retain stock caliper
    Now, there was speculation on www.accordinglydone.com on this large thread they had dedicated to this and the 11.2" front brake upgrade. Anyhow, just to clarify things, the 1998-2002 Accord front hub assemblies will NOT work for this conversion. I ordered these 98-02 Accord front hubs, thinking it was a cheaper alternative to the 98-99 Acura 2.3CL front hubs to see if they would work. Well, I ended up ordering the 98-99 Acura 2.3CL hubs and now have them side by side.
    The differences and why the 98-99 Acura 2.3CL hubs work:
    - both have same bolt pattern
    - both have same hub flange outer-diameter
    - both have same set screw hole pattern
    - both appear to have same spline count & pattern from outside of hub, looking in
    - differences lie in the turned shaft that is pressed into the wheel bearing
    98-99 Acura 2.3CL hub:
    - inner spline side is wider
    - turned shaft outer-diameter is 1 15/16"
    - turned shaft length is 1 5/8"
    98-02 Accord hub:
    - inner spline side is not as wide
    - turned shaft outer-diameter is 2 1/16"
    - turned shaft length is 1 9/16"
    * If I get time, I'll take a few comparison pics. *
    genious.........
    Finally Up and Running. Numbers to Follow. Check my MR
      i wanna do this is that all you think it will take (im gonna be doing it on a 5th gen but with the suspensions being so similar it shouldnt matter) a DIY would be amazing too, im actually very surprised more people havent done this
      -Mark-
      CB7
      CD5
      And if i could swim I'd swim out to you in the ocean
      Swim out to where you were floating in the dark.
        not too had to do eietehr...i did this and went with bigger brakes (prelude rotors and calipers) as well and i love it
        Originally posted by fizzbob7
        Originally posted by ACC0RD22
        So. Cal OUTLAWZ
          I plan to do this rotor over hub swap within the next couple weeks. I'll try to keep you all posted on it
            I will be doing my conversion soon as well, once I receive the EBC rotors and Hawk HPS pads. I have the Acura hubs and Accord wheel bearings already. Sorry I did not take comparison pics yet, it was really late the night I typed this thread up and I had to go into work at 6 am.
            Anyhow, yes I thought and knew about the VTEC prelude upgrade to 11" rotors, but I price that all out and it was like $400-500 to do it right. I realized that my new stock brakes on the 90 EX I was driving at the time (I installed new stock rotors, pads, reman. calipers) brake great...however, they are stock and won't hold to constant hard braking and brake fade will occur. So I decided the stock setup is fine, I just need to get more heat resistant and better heat dissipating material. If I'm not happy with these rotors, then I can always change them...go with Powerslot or some Brembo parts. Now that rotor changes will be easier
            My apologies for no photos after the install...
            98-99 Acura 2.3CL hubs & 90-93 Accord wheel bearings:
            Hawk HPS pads for Akebono caliper & 98-02 Accord EBC rotors:
            Hubs & rotors assembled:
            Installation photos of conversion:
              Where were you a couple of weeks ago! I concur on the parts being different, I just encountered the same thing. As measured with a micrometer, the hub isn't even close to fitting in the Accord wheel bearing.
              I am doing the Prelude VTEC front brake swap, as well as a rear disk swap using the 94-97 suspension from a coupe. I will try to take pictures and document both operations if possible.
                bump this thread up for those still having to deal with pressed on rotors....
                going to be doing this as soon as i get my rear disc conv. as well..
                thanks for all the good info..
                  nice job man, thanks for savin me the troubles. BTW how much do the CL hunbs and bearings run ?
                  Formerly 91AccordExR33
                  11.68 @ 127mph
                  417whp/375wtq
                  Sold: 8/2016
                    Yes exactly! Might as well upgrade to bigger rotors and calipers if you're gonna do all this work. I highly recomment this mod.
                    My CB7 is now ***FOR SALE***
                      CL hubs brand new are like 80 a piece, i found them for 74 on honda tech. bearings are like 48ish a piece then you gotta pay 10 dollar shipping on top of that. (i have some for sale for 75 shipped)
                        If you can find em at a junkyard- you can get the complete Knuckle(or Spindle) assembly for like $75 each.
                        I just got mine at Yale's in Connecticut for that price- and they were from an Acura 2.3 CL. I prolly shoulda swapped my ball joints at the same time, but didn't give it much thought. I think my original ones in the Accord knuckles were tighter.
                        Good Luck
                        Chris
                          Careful where when you get them from a junkyard. Obviously check for rust and bent parts. I ordered mine online from a junkyard in Arkansas and I got some rusted out knuckles. Luckily the hub was fine, but the wheel bearings were totally shot. I ended up paying 120 shipped I think for both and throwing most of it away!
                          Buy it new, you'll feel better about it.
                          "Sticker this, censor this, ban this
                          We got something to say!
                          Police this, condemn this, damn this
                          We'll be heard anyway!
                          Middle finger is the flag that I wave when I'm silenced!" - MuDvAyNe, "Silenced"
                            can somone please post a pik of cl hubs? i mean everything we need exept the rotors...i bought some stuff at my job and it said hub asembly but i mean, i dont noe if its that?i mean its the same number for the wheel bearing...i dont noe if its becouse it comes together( hub plus bearing?) or what. i noe what i bought said 99 cl wheel hub assembly, and its got the four holes to put on the studs, but its the same part number i got for accord bearings....wtf? is this the rite shit?
                            sorry for being an idiot...i just dont get it.
                            I Ain't cocky,I'm confident.And when u say im the best it's a compliment.!
                              that's why there's awsners to questions
                              http://www.accordinglydone.com/forum...ead.php?t=8300
                              Brake Upgrades [In Progress]
                              Ok folks, upon looking at tons of info of brakes, and remembering the headaches i got just trying to find out one bit of information, i have created this thread....hopefully for simplicity.
                              this is how it's going to work. I want you people that have done brake upgrades (rotor over hub, larger rotors, better calipers, etc.) to post DESCRIPTIVELY what you have. Part numbers would be awesome.
                              As replies come in, I will keep this thread as clean as possible, and hopefully it will become a very good reference.
                              Parts that are proven the same:
                              4th gen front knuckle - 5th gen front knuckle - 98 CL 4 cyl front knuckle
                              4th/5th gen front wheel bearings - 98-99 Acura CL 2.3 front wheel bearings
                              98-02 Accord V6 front calipers - 98+ Integra Type R calipers
                              98-02 Accord V6 front rotors - 98+ Integra Type R front rotors
                              98-02 Accord V6 rear rotors - 98+ Integra Type R rear rotors
                              Parts that are not the same:
                              4th gen rear knuckle - 5th gen rear knuckle
                              98 4cyl Hub - 98-99 CL 4cyl Hub
                              SETUPS:
                              lightningd - 5th gen
                              5th gen wheel bearings
                              98 2.3 4cyl CL hubs (Acura P/N: 44600-SY8-A00) (NOTE: comes with studs)
                              98 2.3 4cyl CL 10" Brembo Blank rotors.
                              5th gen calipers
                              Axxis Ultimate Brake pads
                              ATE SuperBlue DOT 4 Brake Fluid
                              zebro racing
                              Brembo OEM size cross drilled rotors
                              Steel braided lines
                              kapao818 - ??? gen
                              Stainless Steel Lines
                              Motul RB600 DOT Brake Fluid
                              Brembo Blanks
                              EBC Greenstuff Pads
                              Gennady - 4th gen Prelude Si 4WS
                              93 Prelude VTEC 11.1" Rotors
                              94 Legend GS 2-piston Calipers
                              93 Prelude VTEC 23T Caliper Brackets
                              93 Prelude VTEC 1" Master Cylinder
                              aero3685 - 4th gen
                              99 Acura CL 2.3 Hub
                              99 Acura CL 2.3 Rotors
                              99 Acura CL 2.3 Bearings
                              91 Accord Calipers
                              91 Accord Pads
                              Chris - 5th gen EX
                              5 lug conversion
                              94-95 Acura Legend dual-piston front calipers
                              94-97 Honda Accord rear calipers
                              98+ Integra Type-R front and rear rotors
                              GZERO - 5th gen
                              95-97 Accord V6 Rotors (11.1")
                              95-97 Accord V6 Calipers (came refurbished with brackets)
                              95 Accord Wheel Bearings
                              phatdoughnut - 4th gen (91 non abs)
                              99 CL front knuckles (minus ABS)
                              94 Prelude VTEC 11.1" OEM front rotors
                              94 Prelude VTEC 23t front calipers
                              93 Accord Ex rear discs
                              94 Prelude Front oem pads
                              93 Accord Oem rear pads (minus ABS)
                              Here is a document created by Chris:
                              Single-piston brake upgrade:
                              OEM Honda front calipers from 95-02 Accord V6/wagon, 93+ Prelude VTEC, or 98+ ITR
                              OEM Honda 25T brackets
                              rotors for 95-97 Accord V6/wagon
                              Dual-piston brake upgrade:
                              OEM Honda front calipers from 94-95 Legend GS Sedan
                              OEM Honda 25T brackets, 28T with caliper may work too
                              simple rotor-over-hub conversion:
                              OEM Acura 98-99 2.3 CL front hubs
                              rotors for 98-99 2.3 CL
                              pads - any options
                              Optional 94-97 Accord front wheel bearings
                              Single-piston brake upgrade with rotor-over-hub conversion:
                              OEM Honda 23T brackets
                              rotors for 98-99 Acura 3.0 CL or 93-96 Prelude VTEC
                              pads - any options
                              Dual-piston brake upgrade with rotor-over-hub conversion:
                              pads - any options
                              Single-piston brake upgrade with 5-lug conversion:
                              OEM Honda 95-97 Odyssey front hubs
                              OEM Honda 95-97 Accord V6/Odyssey front wheel bearings
                              OEM Honda 95-97 Accord V6/Odyssey front knuckles
                              OEM Honda 97+ Prelude rear hub/bearing assembly
                              front and rear rotors for 98+ ITR (rear is also 98+ Accord V6)
                              Dual-piston brake upgrade with 5-lug conversion:
