This is the common "rotor-over-hub" conversion listing of parts for our 90-93 Accords.
98-99 Acura 2.3CL front hub assemblies
90-93 Accord wheel bearing assemblies
98-02 Accord or 98-99 Acura 2.3CL front rotors
90-93 Accord pads (for Akebono or Nissin front calipers)
retain stock caliper
Now, there was speculation on www.accordinglydone.com on this large thread they had dedicated to this and the 11.2" front brake upgrade. Anyhow, just to clarify things, the 1998-2002 Accord front hub assemblies will NOT work for this conversion. I ordered these 98-02 Accord front hubs, thinking it was a cheaper alternative to the 98-99 Acura 2.3CL front hubs to see if they would work. Well, I ended up ordering the 98-99 Acura 2.3CL hubs and now have them side by side.
The differences and why the 98-99 Acura 2.3CL hubs work:
- both have same bolt pattern
- both have same hub flange outer-diameter
- both have same set screw hole pattern
- both appear to have same spline count & pattern from outside of hub, looking in
- differences lie in the turned shaft that is pressed into the wheel bearing
98-99 Acura 2.3CL hub:
- inner spline side is wider
- turned shaft outer-diameter is 1 15/16"
- turned shaft length is 1 5/8"
98-02 Accord hub:
- inner spline side is not as wide
- turned shaft outer-diameter is 2 1/16"
- turned shaft length is 1 9/16"
* If I get time, I'll take a few comparison pics. *
98-02 Accord hub:
