The cruise control on my ride hasn't worked since I saved it from the scrap yard. Basically I wanted to see if the light was burned out on the switch and the steering column control worked correctly.
I used a diagnosis chart from a '90 model accord so I hope I did it right:
In my diagnosis I tested the orange wire (speed sensor) and found constant 12V so I'm going to diagnose the speed sensor next. The speedo in the dash must be cable controlled if the VSS is bad. There are no speedo or tach issues on the dash.
Also found the green/white (brake light switch) to have no effect when pedal was pushed. My brake lights work though so I was wondering if the 93 had a separate relay for this. I'll keep digging, it sucks to make long drives with no cruise or a/c.
All other diagnosis on the chart above seemed normal.
