Since LadyG posted a DIY on axle replacement, I decided to post this up on just replacing the boots. Sometimes the axles aren't clicking, but a boot or boots are torn.
This DIY requires a lot of patience. I like the idea of keeping my OE Honda axles, rather than getting some remans due to a torn boot.
You can follow LadyG's thread HERE to see how to remove and install your axle. I won't cover that part of the procedure, since LadyG has already done a very good job of doing that.
You can get any brand boots, but I prefer the ones from Napa.
****NOTE, If you are replacing the outer boot, you will need to replace both boots. This DIY covers both.
Here are the part numbers:
Inner:
Outer:
Here's what's needed:
Close up of the hand tools:
What comes in each kit:
1. Cut the bands from the outer CV boot:
2. Remove the old boot:
Inner:
Outer:
