Go Back   CB7Tuner Forums > Site Features > DIYs > Interior DIYs
Old 04-04-2013, 12:49 AM   #1
lucifer1
lucifer1 seems to have made some friends! lucifer1 seems to have made some friends!
INT: Sedan Door Panel Removal
Tools needed
Philips screwdriver
Small flat blade
Removing The Front Passenger Panel:
Drivers door is similar
1)Use small flat screwdriver and pop out the clip in the upper front corner.
2)Use a small flat screwdriver and pop up the screw cover in lower rear of panel and remove the philips screw.
3)Use a small flat screwdriver to remove screw cover from armrest pull and remove philips screw.
4)Use a small flat screwdriver and pop up the screw cover behind the pull handle and remove philips screw.
Slide handle forward to front of car to release the hooks and pull towards yourself. Remove door lock switch wire connector(A) and unclip rod(B). Remove door panel screw(C)
After all fasteners are removed, remove panel by pulling with your hands starting at the front and rear bottom of the panel.
After the clips are released, push upward from the rear to unhook the top of the panel.
Unclip the window switch and courtesy light connectors
Reinstall in reverse order
Removing The Rear Panels:
Removing the rear panels. This is similar to the front front but easier.
Remove the interior handle as instructed for the front except there is not a door lock switch to disconnect
Remove the screw behind the interior handle
Remove armrest pull handle screw cover and screw
Pull the panel from bottom to release the clips, then push upward from the rear to remove the panel.
Disconnect power window switch and courtesy light connectors.
Reinstall in reverse order.
lucifer1 is offline   Reply With Quote
Old 04-04-2013, 01:07 AM   #2
Jarrett
This is a great guide. It's one of those simpler projects that not everyone feels comfortable with doing but is easy once you're familiar. You've done well to show the beginning users just how easy of a process it is.
Old 04-04-2013, 10:13 AM   #3
LadyG
Golden
LadyG has a HUGE cock! LadyG has a HUGE cock! LadyG has a HUGE cock! LadyG has a HUGE cock! LadyG has a HUGE cock!
The indicator circles in your pics are great. Well written, easy to follow!
Good Work!
LadyG is offline   Reply With Quote
Old 04-07-2013, 01:25 PM   #4
Bad_dude
Bad_dude seems to have made some friends! Bad_dude seems to have made some friends!
Question
Always good DIY from this guy. Lol.
Could you do one on regreasing the windows for smoother rolling?
Thanks.
Bad_dude is offline   Reply With Quote
Old 04-08-2013, 02:26 AM   #5
CB7_JAY91
CB7_JAY91 is cool... so far.
Awesome write up!!
Jay
HondaLina
91' Accord EX R JDM H22A
CB7_JAY91 is offline   Reply With Quote
Old 04-10-2013, 12:41 PM   #6
10thAnnivCB7
10thAnnivCB7 is cool... so far.
I lost my door handle screw and from now and then it comes off
10thAnnivCB7 is offline   Reply With Quote
Old 04-18-2013, 08:24 PM   #7
mugencivic4dr
mugencivic4dr is cool... so far.
this is exactly what i was looking for, thanx for posting pics on how to remove the panels.
FRIENDS
DONT LET
FRIENDS
ROLL ON
ROTA'S
mugencivic4dr is offline   Reply With Quote
Old 01-05-2018, 04:54 PM   #8
excalibur02
Wanna be JDM whore
Uploaded lucifer1 pictures. Photobucket is wack
Instagram username MAURO02
