As some of you may know, I have a 1993 Honda Accord SE Coupe. While I love the fact that it came with leather from the factory I'm not overly pleased with the fact that it is tan. A few weeks ago while roaming the junkyard I found a 1991 Honda Accord Phoenix Red DX Coupe. I took all of the lower interior trim out of it, for the ever elusive black trim for our cars sedan or coupe. After installing all the rest of the interior trim, I only had the door panels left. I did not look at them closely until after fully disassembling both door panels. Then realized that this wasn't going to be a simple undertaking. So this lead to the birth of this DIY.
**Note the way I have done this will only work if you have the leather inserts from an SE coupe. The black door panels are going to get hacked up, as you will see below.
Tools needed:
Pen
Dremel
-Multipurpose Rotozip bit
-Large and small sanding drum with extra sanding rolls
-Flexible extension (Not a must but very helpful.)
Phillips Screw Driver #2
Flat Head Screw Driver Small
Drill
3/8" Drill Bit
Tape Measure
1. Fully disassemble both door panels, you will end up with the 5 pictures below
Door Pockets
Door Handles
Black Door Panel
Tan Door Panel
Tan Leather Insert
If you pay close attention between the 2 door panels you will notice how different they are.
2. Once the door panels are disassembled I start working on removing the cloth insert from the black door panel. These are glued on and somewhat of a bitch to remove. I tried a few methods, what worked best for me was to just spray the entire insert down in Simple Green. Get it fairly wet to the touch, but not so much that it is running out of the cloth all over. We can continue on with some of the other steps before this is fully removed. I let it sit out overnight, sprayed it again before I went to work. Then after work I sprayed it down one more time. While wet I just started lifting the cloth at the corner, and slowly peeled it all back. This took about 5 minutes after the Simple Green had some time to break down the glue a little. (Note I continued to work on the other steps after the first application. But this does need to be finished before step 8.)
3. Create a pattern off the tan door panel for the door pocket.
4. Trace pattern onto black door panel.
5. Cut black door panel with multipurpose rotozip bit. Clean up edges with sanding drums. Drill holes with 3/8" drill bit.
6. Using the door pocket figure out where to drill, and cut your hole for the courtesy light. Clean up the cut using the sanding drums.
Marked and ready to cut and drill.
Cut and drilled.
7. Install door pocket. Using the speaker cover mark the hole to be drilled for it, and drill out the rivet that holds the old speaker cover mounting tab. Install speaker cover.
8. **The cloth insert must be removed by this point.** Cut out the raised area of the door panel along the armrest and forward.
9. Cut along the back of the door handle to create a space for the leather insert to rest in.
10. Measure and mark out where all the tabs are on the leather insert, then cut the slits.
11. Set the leather insert into the door panel. Trace around the back lower corner of the insert, onto the door panel. I used a standard pen, as the ink will wash off and doesn't rub off as easily as pencil graphite.
12. Now the time consuming part. Lift the vinyl and its backing from the door panel. I did this using the small flat black screw driver. Lift it only to your traced line or just past it. Now while holding up the lifted vinyl use the dremel with a sanding drum to sand the door panel. Sand it down until it matches up with your traced line on the front. You will have to pause often and wrap the vinyl around to see how you are progressing. Sorry I should have taken a few more pictures to try and explain better. Once finished do the same for the front. Just don't mark the front until the rear is done. The leather insert will seat much nicer, making it easier to trace the line.
Door Panel Rear Cut Finished
Door Panel Front Cut Finished
13. Set the leather insert into the door. It should fit well now, even though it doesn't want to sit in on it's own yet. Pushing the leather insert as much as possible fit the door handle to the door panel and mark where the tabs are and the holes. Using just the leather insert trace the pattern of where the front of the door handle sits, and it's hole there as well.
Door Panel Marked for Rear Section of Door Handle
Door Panel Marked for Front Section of Door Handle
14. Cut out the area marked for the tabs and the front of the door handle, once cut sand to clean up. Drill out the marked holes with a 3/8" drill bit. I forgot to take a picture of this specifically. You can see what was done in the next picture.
15. Measure and mark out the new door handle, using the tan door panel for measurements. I didn't take a picture of the marking, but here it is after being cut.
16. Door panel ready for reassembly. Looks rough but I promise it will turn out good.
17. Reassemble door panel. I added washers to some of the screws to help hold them down in areas that were cut away.
18. Fix any broken off tabs that hold the door on. I carefully pried these out of my tan door panels. Then grind the teeth most of the way down, you want to leave some just to add surface area for the epoxy to grab onto. After grinding down the teeth a bit, I used a Dremel with a 1/2" sanding drum and cleaned off all the old glue and the coating on the metal. Do this on all surfaces that contact the door panel and the top of the clip. Rough up the door panel where the clip rests with the sanding drum. Apply epoxy to the door panel in the roughed up areas. Set in the door clip and apply more epoxy over the entire top surface. You want a nice even coating all the way across the top of the clip. We really want this sucker stuck to the door panel. I used this. 3300 PSI bond strength. I hope it can hold up. I did not install the plastic clips yet as I want the epoxy to fully setup before having to be pulled on.
Door Clip 1
Door Clip 2
19. Door panel ready for installation.
20. Enjoy the fruits of your labor!
Hope some of you might find this useful!
Tools needed:
Pen
Dremel
Drill
3/8" Drill Bit
Tape Measure
Door Pockets
Door Handles
Black Door Panel
Tan Door Panel
Tan Leather Insert
Cut and drilled.
Door Clip 1
Door Clip 2
