AkkordLayinKit : 1992 lx
Some of these picture are rather old, I will get new ones up once the swap and paint is complete.
ENGINE:
*JDM F22B-DOHC
*Exedy Clutch
*Fidanza 8# Flywheel
*Nology Hotwires
*JDM P39 ECU
*DC Sports Header
*ApexI WS Catback Xhaust
*MagnaFlow/Carsound Cat.
*MSD SCI-L Ignition Box
*MSD Blaster SS Coil
*MSD Dizzy Cap
*MSD Start/Retard Controller
*AEM Cold Air Intake w/ bypass valve
*AEM Fuel Rail
*AEM Cam Gears
*AEM Adjustable Fuel Pressure Regulator
*Polished Valve Cover
*NOS Wet kit-60 shot
*WeaponR Throttle Rotor
*AC Autotechnic Cam Seal
WHEELS:
*17" TenzoR Shu 4's
*Kumho rubber
*Brembo Slotted Rotors
SUSPENSION:
*Parker-EAI Air cylinders
*Parker Fast Valves-Front
*EAI Manifolds-Rear
*1/2" Airline
*(2)Viair 450 compressors
*10-Switchbox
*6 gal Tank
*Dual 300 psi Gauges -White
*3-Wheel Setup-Check Valve trick
XTERIOR:
*Shaved: antenna, emblems, front/rear door handles, side body moldings, holes in front bumper and rear bumper, trunk, molded sides skirts
*Gen 4 Euro tails sprayed Transparent Candy Apple Red
*VIS: carbon-fiber Invader hood, Combat rear(custom modified), Xtreme sides(molded into body)
*Ground Designs Street Fyghter front(custom modded)
*One-peice projector headlights
*M3 mirrors w/ LEDs
*Fog Lights
*Clear Bumper Lights
*Sparco Hood Pins
*Fiberglassed Grille
*Platinum Window Tint 35%
*McCulloch HID kit
INTERIOR:
*White face indiglo gauges
*Air Ride Gauges in dash
*Autometer: Air/Fuel and Volt gauges w/ pillar pod
*Painted door panel inserts
*Fiberglassed rear deck speaker boxes
*Tweeters in door panels
*Alarm siren in air vents
*Custom rear door-poppers
AUDIO:
*Sony: deck, cd changer, speakers
*MTX 12" 8000 subs
*JL Audio 500/1 amp
^most audio has been removed
FUTURE PLANS: ..................?
Also feel free to give me your opinions good or bad, and ideas if you have any.--Jay
ENGINE:
*JDM F22B-DOHC
*Exedy Clutch
*Nology Hotwires
*JDM P39 ECU
*DC Sports Header
*MSD Dizzy Cap
*AEM Fuel Rail
*AEM Cam Gears
WHEELS:
*17" TenzoR Shu 4's
*Kumho rubber
SUSPENSION:
*EAI Manifolds-Rear
*1/2" Airline
*10-Switchbox
*6 gal Tank
XTERIOR:
*M3 mirrors w/ LEDs
*Fog Lights
*Sparco Hood Pins
*McCulloch HID kit
INTERIOR:
AUDIO:
*MTX 12" 8000 subs
*JL Audio 500/1 amp
