Updated: 6.25.15
Under The Hood:
- Polyurethane Coated Engine Bay (Bed Liner, By Protecoat)
- Modified Shock Towers (by Buddha Concept Designs)
- Werd Werx Wire Tuck, Fuse Box and Battery Relocation
- JDM H22A
- H22 5spd Transmisson M2F4
- Auto to 5spd Swap/Conversion
- P28 ECU Chipped (Dyno Tuned by Import Auto Pros)
- Werd Werx Customized/Tucked Engine Wire Harness
- Street Port & Polished Head (by Nastie Garage)
- Blox Dual Valve Springs
- B&M Fuel Pressure Gauge
- H23/F22 Manual Tensioner Conversion
- ESP Polyurethane Motor Mounts
- Werd Werx Edition H22 Valve Cover (Red Wrinkle)
- FFC Fender Washers and Bolts
- FFC Black Anodized Radiator Brackets
- PWJDM Valve Cover Washers and Bolts
- PWJDM Carbon Fiber Spark Plug Cover
- PWJDM Cam Cap Cover
- NGK Spark Plug Wires
- NGK Iridium Spark Plugs
- BB6 Prelude Intake
- BB6 Prelude Header/Downpipe
- OEM Cat. Converter
Interior:
- Custom Made Harness Bar by Mochi
- Sparco Four Point Harnesses
- Automatic Seat Belt Delete
- Werd Werx Edition RSX Front Seats
- Black Dash Swap
- Black Door Panels
- Black Rear Panels
- Black Carpet
- Rear Seat Delete
- Grey Wagon Center Console
- Grey A & B Pillar Panels
- Grey C Pillar Panels
Exterior Modification:
- Paint = Range Rover Bali Blue (by Tim @ Mr. Old Habits) #itsnotpurple
- Rear Fenders Pulled & Rolled
- Werd Werx Chassis Mounted Wind Splitter/Bumper Lip Protector
- Werd Werx Custom Rear Diffuser
- Shaved Antenna
- Shaved Trunk Emblem
- Shaved Washer Fluid Nozzles
- 92/93 JDM One-Piece Headlights (Blackhoused)
- 92/93 Front Bumper Conversion
- 92/93 Rear Bumper Conversion
- 92/93 Side Moldings
- 92/93 Amber Bumper Lights
- 92/93 Sedan Trunk Conversion
- 92/93 Red/Clear Sedan Tail Lights
- CD5 Greddy G-Racer Front Lip
- CD5 VIS Techno-R Side Skirts (Mugen Replica)
- G Square Replica Grille
- Depo Amber Side Markers
Suspension/Foot Work:
- Function & Form Type Two Coil Overs
- RA1 Odyssey Front Knuckles
- RA1 Odyssey Front Hub/Bearings
- BB6 Prelude Rear Hub/Bearings/Rotors
- Werd Werx Edition Acura RL Front Calipers
- FFC Acura RL Caliper Brackets
- Nissan 350Z 12.8" Front Rotors (Centric brand)
- FFC Rear LCAs
- FFC Rear Toe Arms
- Matrix Rear Lower Tie Bar
- Ingalls Front Adjustable Anchor Bolts
- RAYS Gram Lights 57 Maximum Pro 17x9 +16
- BFGoodrich G-Force KDW2 Tires
Audio/Electronics:
UNDER CONSTRUCTION
Werd.
