car stalled while diving
    i was cruising along and my car sputtered and stalled. car wouldnt start after that. i changed the ignition coil and the main relay and it still wont start. it would turn and seem to start for a fraction of a second, but wont hold. what could be the problem? HELP!!
    search.
      distributor...
      -1993 Accord EX SOLD
      -2012 GMC Canyon V8 4x4
        Originally posted by 91accord4door
        search.
        How about helping next time instead of just saying search this isn't honda-tech
        accordpoop, let me be the first to welcome you to the board
        Have you checked the ECU for any codes? A how to can be found here:
        http://www.cb7tuner.com/vbb/showthread.php?t=21259
          Very Common Happen to Me
          Check the igniter , the way accords work the igniter gets a signal from the starter then bounces a signal BACK to the coil and then you have spark its kinda strange and im not good at wording it but it goes like this
          Turn Key ---> Starter Spins ----> spark goes right through the coil bypassing it tells the igniter to send a spark back to the coil and fires the coil , i dont know why its done this way but most times if the main relay is good and the coild is good then it is the igniter ,,, Hope This Helps ,,, Look up my threads , one of my First threads ever was a HELP cry cause my car was about to be towed and i didnt know what the hell was wrong with it man , seemed like a fuel problem but really ended up being the igniter , also this may help alot and its cheaper than buying a whole Distributor man . L@@K
          http://techauto.tripod.com/s.htm Good Luck
          -Sean- AKA Noxidea
          Fore Sale" My Ride "Best Time To Date 14.9 @ 94 MPH ...
            hey thnx for the help guys...ive given up, im just going to tow it to my mechanics class and get it fixed there...im getting too frustrated!!
              had same problem...but it had to do with my fuel pump..changed trhe relays and its fine...also could be distributor tho
                ya. my two cents is dizzy.
                edit:
                I just rememberd that that happend to me a long time ago, and it was my vavle...damn I can't remeber the name, but it's on the IM, just between the IM and the head. It's black...errr...someone help me out. Mine got stuck CLOSED and so it choked the engine. Did your revs go crazy b4 it cut out? Mine did. Clead the vavle and opened it...and all was returned to normal.
                2DAO (2 Door Accord Owner)
                JDM H22 DOHC 200/161 2.2L
                My members ride: http://www.cb7tuner.com/vbb/showthread.php?t=20385
                  got my car towed to class today and tested all the ignition and it was fine...there was no fuel pressure so i checked the relay and it was fine...it turned out to the fuel pump!! well...that's what my teach says...but wont know until tomorow when i drop the fuel tank down...
                    Its defintely the fuckin distributor I had the same bullshit happen to me. I hate those fucking the=ings they are just plain weaksauce.
                      Same thing happened to me. It was the igniter as well.
                      My swap thread
                      Main relay proplems?--DIY
