i was cruising along and my car sputtered and stalled. car wouldnt start after that. i changed the ignition coil and the main relay and it still wont start. it would turn and seem to start for a fraction of a second, but wont hold. what could be the problem? HELP!!
car stalled while diving
distributor...
-1992 Accord EX H22 234whp 185wtq
-1993 Accord EX SOLD
-1995 Accord EX Wagon Daily Driver
-2012 GMC Canyon V8 4x4
How about helping next time instead of just saying searchOriginally posted by 91accord4doorsearch.
this isn't honda-tech
accordpoop, let me be the first to welcome you to the board
Have you checked the ECU for any codes? A how to can be found here:
http://www.cb7tuner.com/vbb/showthread.php?t=21259
Very Common Happen to Me
Check the igniter , the way accords work the igniter gets a signal from the starter then bounces a signal BACK to the coil and then you have spark its kinda strange and im not good at wording it but it goes like this
Turn Key ---> Starter Spins ----> spark goes right through the coil bypassing it tells the igniter to send a spark back to the coil and fires the coil , i dont know why its done this way but most times if the main relay is good and the coild is good then it is the igniter ,,, Hope This Helps ,,, Look up my threads , one of my First threads ever was a HELP cry cause my car was about to be towed and i didnt know what the hell was wrong with it man , seemed like a fuel problem but really ended up being the igniter , also this may help alot and its cheaper than buying a whole Distributor man . L@@K
http://techauto.tripod.com/s.htm Good Luck
-Sean- AKA Noxidea
ya. my two cents is dizzy.
edit:
I just rememberd that that happend to me a long time ago, and it was my vavle...damn I can't remeber the name, but it's on the IM, just between the IM and the head. It's black...errr...someone help me out. Mine got stuck CLOSED and so it choked the engine. Did your revs go crazy b4 it cut out? Mine did. Clead the vavle and opened it...and all was returned to normal.2DAO (2 Door Accord Owner)
JDM H22 DOHC 200/161 2.2L
My members ride: http://www.cb7tuner.com/vbb/showthread.php?t=20385
