Stuff you need
-paint of course(High Temp)
-Primer
-Sand paper 400 and 2000 grit
-Polish
-Wax
-cloths
-paint stripper
Steps:
1. Spray the valve cover with the paint stripper, let it sit for 20 min or so.
Then hose it off and everything should come off, if not you can respray it with the stipper again
2.Sand the valve cover down with 400 grit paper and then clean it with alcohol.
3.Tape any areas where you don't want paint in
4.Spray some primer on it like 2-3 coats, waitng 10 min between each one.
5. After the primer, comes the color that you want spray about 3-4 coats again 10 min between each coat.
6. Wait until the next day, to start sanding it with 2000 grit paper, after sanding it all down begin to start polishing it, then wax it and your results should look like this:
Before
After
Note* you don't have tape the letters you can just sand them down after your finished painting
-Primer
-Polish
-Wax
-cloths
-paint stripper
Steps:
Before
After
