okay this is my very first diy post so bare with me.if I miss some stuff just ask without getting pissy
I did this diy already so Im just showing how I did it.
tool and suplies needed:
screw divers philips/flat head
pair of pliers/not in pics
dremel and cutting tool
gutter guard mesh-home depot
black paint
alluminum plumbling tubing( the stiff once not the flimsy ones.
1) remove your bumper tail light by taking off this screw(passenger side)
2) next cut where the orange meets the housing( plastic will burn so you will have to chip them of when cooled.then replace in with the mesh, cut it with the dremel so its easier and shape it around the housing, overlap it aboit an inch so you can wrap it around the housing, fold it flat against the housing as good as you can. sorry no pics. then once you get it into shape, you can go ahead and paint it blk or wich ever color you want, then once dry re install on housing.
3) next cut the the back part on the line, the turn signal housing is gonna be your actuall scoop.
4) then imagine the back being being cut already, take your tubing duct and flaten it and shape it so it fits the back bart of the housing. then drill 2 holes for the screws on the bottom of the housing.
5) now go under neith the car and remove the mud guards for the intake side, their should be room in their and cut a hole the size of the duct pipe your using like your installing CAI.
6) now bend the pipe so it runs along the shape of the car under neith from the top to the botom,( its gonna be tough) once you get the duct allign with the housing on the bottom screw in the duct with the hosusing with the 2 holes underneith the housing.(sorry now pics) I have kids,lol
7) then secure the duct on top by using the scew clamp the one you use for the intake head by having the flap facing liike the pic and drill a hole then scew in and allign the duct with the intake heads middle portion then your done.I hope
if I missed a few stuff let me know cuzz Im new at this. sorry. I tried.
here the sleeper scoop look
here is my latest front end look. check out the left over H emblem I had from teh front grill hack, prelude stylez
I hate to here people flaming at me on this diy because I did infact took time on my buisy schedule to dot this for yall.
let me know what you guys think
black paint
