Hey guys, I need some serious help...i've tried to diagnose this but im coming up with nothing....
Problem: Radiator fan is off when ignition is on, and only turns on when I turn the ignition off.
Symptoms: boiling during driving
Solution:___________________________________________...fill in the blank?
takes:
-fan temp sensor/switch (replaced....problem still exists)
-fuses (all are good)
-relay (switched relays....problem still exists)
Thanks in advance
takes:
Thanks in advance
....thats a lot...even in terms of Canadian currency
