HELP! Rad Fan Off When Ignition On...Boiling
    Hey guys, I need some serious help...i've tried to diagnose this but im coming up with nothing....
    Problem: Radiator fan is off when ignition is on, and only turns on when I turn the ignition off.
    Symptoms:
    boiling during driving
    Solution:___________________________________________...fill in the blank?
    takes:
    -fan temp sensor/switch (replaced....problem still exists)
    -fuses (all are good)
    -relay (switched relays....problem still exists)
    Thanks in advance
    DEVOTE
    FS: Lokuputha's Stuff
    peanut butter and ham sandwiches
    DEVOTE
      obviously your car is running hot because your cooling fans are not coming on when they are supposed to. I would suggest you replace your thermostat and your thermo switch to start. the switch is on the thermostat housing. good luck.
        http://media.honda.co.uk/car/owner/m...400/16-103.pdf
        How about the timer unit/radiator fan control module?
        http://media.honda.co.uk/car/owner/m.../400/15-62.pdf (few pages in, cooling fan timer unit input tests)
        also see
        http://media.honda.co.uk/car/owner/m.../400/15-48.pdf
        let me know
          also see
          let me know
          accordaffair u r the man, man!...thanks for the links...im going to do some diagnosing....i have a feeling its the Fan Control Module too...
          Thanks
          DEVOTE
            good luck and keep us posted.
              replaced the thermo fan switch....got a new thermostat last year...so im still thinking its the Fan Control Module...
              ...the only problem is the module costs $207.00 ....thats a lot...even in terms of Canadian currency
              DEVOTE
                hmm just by reading it would have thought it was the thermo switch A. that one is supposed to send signal when temp rises to 180 (when car running) to turn on cooling fans. and the thermo switch B sends signal when ur car is off and temps rise to 260 degrees. switch A in on thermostat and switch B is on the front water neck.
                thats strange.....arent both fans supposed to turn on? im not 100% sure about that. have you tested the cooling fan motor??? hook jumpers directly to the battery and see if it turns on, if it does and u already placed the switch and fuses are good. its the timer module.
                best of luck.
                F22a1-->F22A-->H22A-->auto-2-5spd-->K20 6spd-->F22C 6spd RWD-->4G63 6spd AWD-->K24 6spd????
                Sold to: blackice, Myothercar, Rennat, Ilikebigbutts, HA91, DA92CB7, accord91lx, Cb7GHOST, Gemini, whiteaccord92,Warudakumi, jhondayaaj
                Bought from: 93twodoorLX, Datmofo, g7kobayashi, accord_inspire, Accord SiR, Kurobei, UK-Accord, phreakish93, RENR, k-mart
                  the one fan I think only turns on when ac is on.
                    thats true. the A/c fan is the one on the drivers side and the regular cooling fan is the one on the left. Never heard of the timer module failing, but then again, my harmonic balancer just broke, so weird things can happen.
                    Proud owner of the only JJDM full 2.5" catback exhaust!
                      spoke with the mechanic today, and he said he fixed a bunch of swapped accords lately with the exact same problem...
                      symptoms:
                      -temp switch A (beside the thermostat) is not turning on
                      -upper rad hose very hot while lower rad hose is cold
                      -interior of car heats up
                      -rad fans will only turn on once ignition is off
                      -coolant overheats even when rad fans are hot wired and run all the time
                      cause:
                      rusted water pump
                      description:
                      swapped motors are usually left without coolant and exposed to water for prolonged periods of time... The fan vanes, which are steel, will usually rust away.
                      why now:
                      4000rpm for 1000km would cause already rusted and weakened pump vanes to deteriorate eventually leaving almost no vanes to pump the coolant.
                      DEVOTE
                        so the fans were running?
                          was that a honda tech? i would not say its the water pump based on YOUR symptoms and description in the original post.
                            the fans were working but they would not turn on b/c the temp switch near the thermostat wasn't getting any fluid...
                            the lower coolant line is cold while the top one is very hot.
                            Originally posted by SMseagren83
                            was that a Honda tech? i would not say its the water pump based on YOUR symptoms and description in the original post.
                            yes he is, he actually fixed two different engine-swapped Accords with the same problem in the last month.
                            DEVOTE
                              symptoms:
                              cause:
                              rusted water pump
                              description:
                              why now:
                              dude, you need a thermostat then. upper hose hot and lower hose cald means t stat not operating as it should. replace the thermostat man. And I am no kid off the street. I work on cars 5 days a week and if I saw this symptom on a car, I would definitely replace the thermostat to start.
