boot-leg Blacktrax spacer
    i saw green cb7 made 5hp & 5tq with the Blacktrax spacer on his car. well it got me to think'n why can't i just use an extra IAB i have. the butterflys were already removed and the ends JB welded. so i put it on and of corse the studs & bolts were to short. so i hit up different auto shops and couldn't find bolts long enuf. so i put the idea on the back burner.
    well i go out side today so i could start on my ABS removeal. and i tripped on a bolt. i look down and it's three of my AC compresser bolts. i pick it up & run in the house to try it out. there the right thread pitch & they'er long enuf.
    update....only 3 of the AC bolts will work. the two spots that have studs are longer than the bolts. to replace them you need two 8 x 1.25 100mm bolts
    lucky u man....
    My Members Ride Thread ( Do It )
      Pretty cool project out of an extra IAB plate Doing an ABS removal too huh? I'm hoping to remove mine sometime too.
        but isn't the material that's important metal will just transfer heat while their's is like a high grade plastic which doesn't carry much heat....
        THEN: 1993 Accord 10th Ann. Ed.---------------------- NOW: 1996 Accord EX
        My Ride thread
        Flickr
        Originally posted by d112crzy
        And it can only get better. That's the best part.
        All I gotta really say is:
        People of cb7tuner, this AUTO is NOT a joke. It has impressed ME, the hater of auto's.
          the ENTIRE point of the spacer is that its insulating from heat... because its plastic... adding a blank IAB plate wont do anything whatsoever for you.
            Well, not exactly the extra plate will increase runner volume, thus introducing more torque. But still the results will not be the same because the IAB plate is metal, and that conducts heat very well.
            Gary A.K.A. Carter
            [sig killed by photobucket]
              guess you've never heard of air volume & velocity. basic principals of a 4 stroke combustion engine.
                yea tru but the main point of them is the material they are made of to insulate from heat....if it was just meant to be a spacer whats the point...everyone could just use an extra iab plate
                  many cars benefit from increased plenum (V6 VQ 3.5 comes to mind) height and length, however if your going to the work may as well may it a material that doesnt conduct heat.
                  http://www.modernplastics.com/ptfe-v...et-p-1022.html
                    uh...the main point is to make power by making the runners longer. It's not called an insulator, it's called a spacer.
                    I'm sure there wouldn't be much of a power difference between the plastic spacer and a normal IAB plate.(IF, and only IF, both were the exact same design).
                    There's probably more of a difference from cold morning to hot sunny day.
                    IF you're looking for thermal differences, then get one of those phenolic insulating IM gaskets.
                      yes i know that increasing runner length will give power...i meant whats the point of just buying it as a spacer...for that just go to the junkyard and get an iab plate for 10 bucks and unscrew the 4 plates...and bam u gotta spacer for cheap...
                        actually i thought the blacktrax spacers were aimed at thermal isolation... news to me!!
                          there used for both
                            x2..... ..... so for someone like me that already has an IM phenolic gasket, wouldn't benefit much more from this and a stacked IAB plate with butterflies deleted?...
                            My Ride thread
                            Flickr
                              I don't see why people don't do that
