i saw green cb7 made 5hp & 5tq with the Blacktrax spacer on his car. well it got me to think'n why can't i just use an extra IAB i have. the butterflys were already removed and the ends JB welded. so i put it on and of corse the studs & bolts were to short. so i hit up different auto shops and couldn't find bolts long enuf. so i put the idea on the back burner.
well i go out side today so i could start on my ABS removeal. and i tripped on a bolt. i look down and it's three of my AC compresser bolts. i pick it up & run in the house to try it out. there the right thread pitch & they'er long enuf.
update....only 3 of the AC bolts will work. the two spots that have studs are longer than the bolts. to replace them you need two 8 x 1.25 100mm bolts
metal will just transfer heat while their's is like a high grade plastic which doesn't carry much heat....
