i think its been threaded before but some asked for me to do it so i am...
first u need:
phillips screwdriver
drill
tweeters(of course)
and alot of patience to make sure the whole is perfect!!
it took me about 45 mins. to an hour but i didnt have the drill bits that drill big whole i had to use a little drill bit and make alot of holes. well here it goes.
first i unsrewed all screws for the door panel and popped off the panel.. theres two in the lock and door handle area, one in the arm rest area, one by the door light on the lower corner, and one when the doors open but that one jus pops out..
one its popped out dependin on the tweeters u have place where u might want it. mine had a ring around it that locks into the tweeter thats what i used to trace my hole. then i drilled be very careful not to go to big cuz that would be very bad.
after i drilled the hole i got a file and fileda lil to make it fit tighter
test fit. and wire it up to ur door speakers. pop the panel back in, screw all screws in, and turn on the radio make sure everything is workin and sit back and admire....
first u need:
drill
tweeters(of course)
