So, as some of you know, my brother owns a 1970 Chevrolet C10 pickup, which I posted up a while back. Anyways, this thing has never run quite right since he bought it, so we decided to tear the motor down and see what we were working with.
Good lord, I'm surprised this thing ever even ran...
First: I removed the intake manifold to find a STICK in the lifter valley. Like, a real, wooden twig. Inside the motor.
Then, while I was pulling the heads, half the head bolts were barely even torqued, which, not to my surprise, resulted in a blown head gasket between two cylinders on the left bank, which partially eroded the block and head.
And the results of the blown headgasket on cylinder #3:
Oh...did I mention that they used two DIFFERENT kinds of pistons in the motor? All 4 cylinders were bored, but they used two oversized (.030 over) and two standard bore pistons:
Middle two cylinders:
Oh, and apparently it was homebuilt. You know that 60* crosshatch you are trying to get when you hone a cylinder? How about we go for 10*, eh Billybob?
And this, boys and girls, concludes our engine building fail for the day.
