Something really shocking happened to me while pumping gas earlier. While I was reaching to open the gas cap, I guess some static shock happened, and then just like that, fucking fire shot out about 2 feet and burned nearly all the hair off my arm! I seriously thought my car was going to blow right then and there.
Crazy fire while at the gas station
I've seen in a firefighter training video how easily spark can ignite gasoline. Hell it does it in the cylinder all the time, heh.
Thats some crazy shit though, good thing it doesn't explode as easily.
esd= electro-static-discharge right??Originally posted by 93EXaestheticplastic can be used for ESD..
any way that is fuckin insane... how'd you put it out ?R.I.P. 6-10-07
(\__/)
(O.o )
My Rotor DIY
I'm not perfect i will make mistakes if i do just point it out to me
The fire died down after like 2 seconds but then I saw it trying to get inside the gas cap, by then it was already weak and then I blew it out. If I didn't blew it out right there I probably would've been dead and several people at the station. I forgot to mention this earlier, to make things even worse, there was a tanker truck filling up the station less than ten yards away. My friend that was with me shit his pants majorly.
RICE COOKA!!
Originally posted by 92DXThe fire died down after like 2 seconds but then I saw it trying to get inside the gas cap, by then it was already weak and then I blew it out. If I didn't blew it out right there I probably would've been dead and several people at the station. I forgot to mention this earlier, to make things even worse, there was a tanker truck filling up the station less than ten yards away. My friend that was with me shit his pants majorly.
HAHAHAHAHAHAHAHA damy my bad i was imagining ur friend floating in a spa tub..............
::clears throat::
as i said earlier that is fucking insane....
carry on...
If a flame erupts from the nozzle, best thing to do is stick the nozzle into the tank filler neck. It defies instinct, but doing so will suffocate the flame. If it really happened to me I'd prob drop the thing and run, or just try to blow it out like you did.
The fire happened when i was reaching in to open the gas cap. So in that case, the best thing i could've done was probably close the gas door. Yeah i'm suprised i didn't run myself, but if i did that would be one less CB7 and one less shell station, maybe even one less city blockOriginally posted by accordaffairIf a flame erupts from the nozzle, best thing to do is stick the nozzle into the tank filler neck. It defies instinct, but doing so will suffocate the flame. If it really happened to me I'd prob drop the thing and run, or just try to blow it out like you did.
RICE COOKA!!
