Malware problems (I think)
    Anyone know how to get rid of this shit. I have two things running in the system tray that pop up critical warning/system alert balloons. Any help would be great, thanks.
    *Edit* I've run a complete virus scan, and have also used SB S&D to no real avail.
    Always remember that only you can make your dreams a reality.
    Never forget that your style is all that matters when it comes to your ride, but be respectful to others who don't share your vision.
    Proud Alum of the University of Texas at Tyler, Class of 2010
    Ad Aware...
    MYCB7.com
      Did Ad-Aware as well, and nothing has removed it.
        Changed my antivirus to Symantec Antivirus Corporate. Got rid of my problem. Props to my friend Matt who moved from TX to Iowa a couple of months ago.
          The offending app should be popping up at all times. if it says it is a security breach ignore it.
          Download the trial tweaknow to your pc. Download somesort of spyware removal program.
          tweaknow
          http://www.tweaknow.com/powerPack.html
          Here's some free spyware software:
          http://www.stopzilla.com/purchase/dl...E%20REMOVAL_DL
          Top Rated:
          http://www.download.com/Webroot-Spy-...-10598648.html
          Remember the malware is designed to be able to make it through a pc cleaning. You have to out smart it. The above apps won't delete the malware, but they will let you know the name of it. Take your time and when it gives you a report on what needs to be deleted/fixed, don't fix it yet. write them down along with the location and look for the program;run task manager, and you should now be able to tell which processes are the bogus malware.
          Open the task manager in tweaknow. highlight the offending app and select windows to deny access and not let it start up upon windows start up. reboot. now you will be able to delete the files now.Try out the other features of tweaknow and see if you want it.
          Hope this helps.
