Hey everyone,
I didn't know exactly where to put this so here it is. I recently bought another accord. A 97 LX. I pressure washed the engine/bay and about 5 minutes after that it started sputtering in lower rpms. It was driveable but when the gas was pressed rather heavily it would sputter badly and then clear up in the higher rpm range. If i pressed the gas very slowly it would run smooth through the whole rpm range. It ran perfect after about 45 minutes. I did some touching up on the engine with the hose the next day and the sputtering started yet again. It ran fine a while after that. Then then a few days after that i changed the oil pan gasket. After i finished that ( later at night) it started sputtering and stalled out a few times. Then it wouldn't start. It would just just crank and crank and backfire once or twice. I let it sit and the next morning it fired up and ran perfect. Drove it around for about 30 minutes and it was fine.
Does anyone have any ideas on what the problem could be?
I appreciate any help.
Caleb
Caleb
